Rapid Storage Technology
Intel® RST, RAID
2209 Discussions
Intel Rapid Storage Technology Software not showing my array
M1keGreen
I have a HP Z840 and I have built a Raid 10 array which I can access via Disk Manager and mount fine in Windows 10. However if I go into the RST software I can see the two Raid controllers but not the array. One controller has 1 SSD and 4 drives. The 4 drives make up one Raid 10 array. that controller is showing nothing. The other controller has an ATAPI device which is probably my CD drive. That is all thats attached to it.
I want to see the arrays to check health and get notifications of errors. I've updated drivers to the latest version via the HP assistant. Any help would be appreciated.
Cheers,
Mike.
M1keGreen
It was a rookie error. The drives were plugged in to the SAS ports and the array was formed there. This software is for monitoring the SATA ports. Once I switched over and made a new array everything showed up. Sorry for being a rookie.
Maria_R_Intel
Hello M1keGreen,
We are glad to know you found a solution, thank you for taking the time to share this fix, and hopefully, it may help other community members experiencing similar behavior. Since the thread is now solved, we will proceed to close it.
Maria R.
