Rapid Storage Technology
Intel® RST, RAID
2200 Discussions
Intel Rapid Storage not showing any hard drives
JTutt
Device Manager, Disk Management and BIOS show 2 hard drives, but none showing in the graphic window, screen shot attached.
BIOS is set to RAID mode else IRST app would not install.
Want to setup RAID 1 for my two identical hard drives.
What am I missing?
Many thanks to all... Jeff
OS = Windows 7 Ultimate
Board
________________________________________________________________________________
Manufacturer Intel Corporation
Product Name DX58SO2
Version AAG10925-207
Serial Number BTS2128000SA
BIOS Version SOX5820J.86A.0876.2011.0824.0021
BIOS ROM Size 2048 KB
BIOS Release Date 8/24/2011
Processor
Manufacturer Intel(R) Corporation
Processor Name Intel(R) Core(TM) i7 CPU 960 @ 3.20GHz
Processor Speed 2.802 GHz
Stepping 5
Form Factor Socket LGA1366
Hyper-Threading Technology Status Enabled
Hard Drive
Model ST500NM0011
Max. Transfer Mode UDMA 6 (ATA/133)
Active Transfer Mode UDMA 6 (ATA/133)
S.M.A.R.T. Status Enabled
Size 465 GB
Model ST500NM0011
Size 465 GB
Hello jrtuttle,
I understand Intel RST is not detecting the hard drive you have connected to the computer.
Let me apologize for any inconvenience this issue may be causing to you.
There is a chance the hard drives might be connected to the Marvel SATA controller (blue SATA ports). Intel RST will only recognize the SATA drivers that are connected to the Intel SATA controller (black SATA ports).
If the operating system is installed in any of those two drives then it will be necessary to reinstall Windows* if you connect the SATA drive to the Intel SATA controller.
Let me know if you have or not any other inquiry.
Fred D.
Hello jrtuttle,
I was wondering if you still need assistance regarding the hard drives Intel RST is not recognizing. In case you still need assistance just let me know.
Fred D.
