Rapid Storage Technology
Intel® RST, RAID
2207 Discussions
Reactivate Intel RST Cache RAID
MLong3
Hi!
Using a HP Elitebook with Intel RST raid cache. After a Win10Pro boot problem, i deleted the Cache RAID in the BIOS config tool.
Is there any way to reassign the raid or copy the separated data from the disks (SSD+HDD)
Thanks for help!
Hello martinlangbugger,
Thank you for contacting the Intel community.
In this case, if deleted the cache the information will be lost, you should be able to create it again, you will need to launch the IRST and then high light the SSD and you will be able to see the option to accelerate your system.
If this option is not available you will need to contact your system manufacturer to get tips how to do it or if it is possible to do it again on your system.
Ivan U.
I'm following on this post to ask you if your issue has been resolved or if you need further assistance.
Ivan U.
