Rapid Storage Technology
Intel® RST, RAID
2250 Discussions
Intel Rapid Storage problem
Jazek
Hi everyone,
I have problem with Intel Rapid Storage Technology service.
I use Windows 11 Pro on Asus H110M-K with Intel i5 6500 and have error:
The Intel(R) Rapid Storage Technology service terminated unexpectedly. It has done this 1 time(s).
With Event ID 7034 (in Windows Event Viewer)
In Microsoft Community tell me that i need to ask in Intel forum, can someone tell me why i have this error?
I check all components, all is ok, and my HDD and 2 SSD too is ok
n_scott_pearson
Did you check in Apps & Feature applet?
AlHill
Windows 11 is not supported on your processor.
Jazek
And this is because i get this error? Maybe its not so serious error and can use  with this error or this is something serius?
AlHill
The simple fact is  that you are not supported.   Not by Microsoft for using W11 on an unsupported processor, and not by Intel for using a discontinued and unsupported processor.
Jazek
But there is no possible to happen something bad, yes?
Before I used Windows 11 on:
Motherboard: Gigabyte GA-970-A3
CPU: AMD FX6200 ~3.8GHz
GPU: NVIDIA GTX760 2Gb
and 16Gb of RAM and this all is unsupported by Windows 11, but all works realy grate without any error
AlHill
"But there is no possible to happen something bad, yes?"
Venkman:  What do you mean "bad?"
Spengler:  It's hard to explain, but try to imagine all life as you know it stopping instantaneously and finding yourself confined forever in another dimension.
Look, you are not supported.   And, if you took your W11 build from the Gigabyte board with the AMD processor, and put it on the asus board with the intel proceessor, then that is B A D.
Get a a supported OS or supported system, do a fresh build of the OS, then come back.
n_scott_pearson
Just out of curiosity, why do you have Intel RST installed? Are you actually using RAID or do you have an Optane Module/SSD installed? If not, you should uninstall Intel RST immediately; it is unnecessary and can add unnecessary issues/complications to your configuration.
Jazek
@AlHill i like Windows 11 with those changes and this is only error i didnt understand, else is simple on alost every Windows maschines, what i get time to time.
I cant find Intel RST to unistall it, because i didnt have any module ssd drive, even try to find in Device Manager under Hidden Device Drivers
n_scott_pearson
According to the RST documentation, "Press Windows + X keys. Select Device Manager. Find and expand the Disk drives catalog. Right-click Intel® Rapid Storage Technology and choose Uninstall device."
P.S. I want to ensure that you understand where Al is coming from. You had to hack Windows 11 in order to install it onto your older machine. That makes it unsupportable, by Intel and by Microsoft. When things go awry, no one at either company is going to set up such an environment to determine what is causing it to go awry, let alone look for a solution.
Jazek
I install Windows 11 in recovery mode with download from Microsoft and there wasnt be any error or problem with missmatch.
There is problem, i cant fint it in Device Manager, i even reveal Hidden Drivers, there is no Intel RST, like its as if it wasnt on the computer at all
n_scott_pearson
Jazek
Nope, there is no RST on this computer, i cant find it
IsaacQ_Intel
Hello @Jazek, @n_scott_pearson and @AlHill
As the Super Users pointed out, the CPU (i5 6500) doesn't support Windows 11. So, Intel has not assessed what problems could be using that CPU in that operating system. Our suggestion remains to use an OS that's compatible and verify with the motherboard manufacturer if there's a Windows 11-compatible RST driver available.
Since it is required to check with the motherboard's original equipment manufacturer, we will proceed to close it. Please keep in mind that this thread will no longer be monitored by Intel. Thank you for your understanding.
Isaac Q.
