- Marquer comme nouveau
- Marquer
- S'abonner
- Sourdine
- S'abonner au fil RSS
- Surligner
- Imprimer
I have 4 drives in a Windows 2016 server. There are two raid arrays set up as RAID1. I keep having the same drive slot reporting as failed. I've put 2 new drives in there and the RAID rebuilds fine, runs for a couple weeks, then says failed. I'm not sure if I have an MB problem or a software problem.
I took the two old drives that had originally been taken out of the RAID as failed and found that the data seems fine. I used Crystal Disk Info to confirm that the hardware itself is fine.
Any suggestions on how to troubleshoot this? The error notification I receive is as follows:
SATA disk on Controller 0, Port 2: Failed.
Volume Data: Failed.
System Report
System Information
OS name: Microsoft Windows Server 2016 Standard
OS version: 10.0.14393
System name: WIN16A
System manufacturer: Micro-Star International Co., Ltd.
System model: MS-7B48
Processor: GenuineIntel Intel64 Family 6 Model 158 Stepping 10 3.6 GHz
BIOS: American Megatrends Inc., 2.40
PCH: 0xA2C9
Intel® Rapid Storage Technology enterprise Information
Kit installed: 16.0.2.1086
User interface version: 16.0.2.1086
Language: English (United States)
RAID option ROM version: 16.0.1.3397
Driver version: 16.0.2.1086
ISDI version: 16.0.2.1086
Storage System Information
RAID Configuration
Array Name: SATA_Array_0000
Available space: 4 MB
Number of volumes: 1
Volume member: OSVOL
Number of array disks: 2
Array disk: WD-WMATV3656846
Array disk: WD-WMATV6680701
Disk data cache: Enabled
Array Name: SATA_Array_0001
Volume member: Data
Array disk: 9QJ4BAKF
Array disk: WD-WMATV6487410
Volume name: OSVOL
Status: Normal
Type: RAID 1
System volume: Yes
Data stripe size: 64 KB
Write-back cache: Off
Initialized: Yes
Parity errors: 9
Blocks with media errors: 0
Physical sector size: 512 Bytes
Logical sector size: 512 Bytes
Volume name: Data
Status: Failed
Type: RAID 1
System volume: No
Write-back cache: Read only
Initialized: Yes
Parity errors: 0
Blocks with media errors: 1
Hardware Information
Controller name: Intel(R) Chipset SATA/PCIe RST Premium Controller \\Scsi0
Type: SATA
Mode: RAID
Number of SATA ports: 6
Number of volumes: 2
Volume: OSVOL
Volume: Data
Number of spares: 0
Number of available disks: 0
Rebuild on Hot Plug: Disabled
Manufacturer: Intel Corporation
Model number: 0x2822
Product revision: 0
Direct attached disk: WD-WMATV3656846
Direct attached disk: 9QJ4BAKF
Direct attached disk: WD-WMATV6487410
Direct attached disk: WD-WMATV6680701
Disk on Controller 0, Port 0
Status: Normal
Type: SATA disk
Location type: Internal
Usage: Array disk
System disk: No
Command queuing: NCQ
Transfer rate: 3 Gb/s
Model: WDC WD1002FBYS-02A6B0
Serial number: WD-WMATV3656846
SCSI device ID: 0
Firmware: 03.00C06
Disk on Controller 0, Port 1
Status: Normal
Type: SATA disk
Usage: Array disk
System disk: No
Model: ST31000340NS
Serial number: 9QJ4BAKF
SCSI device ID: 0
Firmware: MA08
Disk on Controller 0, Port 2
Status: Failed
Type: SATA disk
Usage: Array disk
System disk: No
Serial number: WD-WMATV6487410
SCSI device ID: 0
Firmware: 03.00C06
Disk on Controller 0, Port 3
Status: Normal
Type: SATA disk
Usage: Array disk
System disk: No
Serial number: WD-WMATV6680701
SCSI device ID: 0
Firmware: 03.00C06
Empty port
Port: 4
Port location: Internal
Empty port
Port: 5
Lien copié
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Honestly I decided to just move on and break the RAID array. I was frusted by your question about whether I had tried other drives in that port. I explained in my original that I have put two new drives in there and within a few days to a week after rebuild, it reports that drive as failed again. I needed to get the server going so I moved on.
From now on I will use only hardware RAID as the Intel software RAID does not seem reliable.
Thank you anyways,
Paul
- Marquer le sujet comme lu
- Marquer
- S'abonner
- Page imprimable
