Rapid Storage Technology
Intel® RST, RAID
2189 Discussions
Maximum size for RST caching SSD?
steam2
I have two motherboards, one with a Z68 chipset, the other with an H77 chipset.
What is the maximum size for Intel's RST caching SSD drive?
Thanks!
Kevin_M_Intel
As a matter of fact At this point there is no limit for this but there is a minimum capacity for the SSD which is 18.6 GB.
Here you have the system requirements for Acceleration:
http://www.intel.com/support/chipsets/sb/CS-032826.htm http://www.intel.com/support/chipsets/sb/CS-032826.htm
Kevin M
AHSU28
I think it have a limitation for maximum cache size.
AHSU28
Intel RST UI shows the answer below. The maximum size is 64 GB for cache memory.
Have A Nice Day
