Rapid Storage Technology
Intel® RST, RAID
2189 Discussions
Intel rapid storage technology driver updation on my Vaio VPCEA16FG
strip6
I have vaio VPCEA16Fg. i wanted to update IRST driver but the installer says "platform not supported".
I have changed my harddisk drive to "Seagate SSHD 1 Tb" recently.
Now my Widows update does not work and after hours of research i have found the IRST driver updation seems to be the solution but Vaio service says no IRST driver update available.
I'm attaching DxDiag & msinfo output to this post. how can i update my driver?
Hans_B_Intel
Hello shekharpati,
If you want to try to install the Rapid storage technology, let me suggest that before installing the driver form Intel download center directly, that you first contact your system manufacturer. They typically should either provide software which is specifically configured for your system or let you know if this is essential to your system.
You can find the download for the RST driver here: https://downloadcenter.intel.com/download/24779/Intel-Rapid-Storage-Technology-Intel-RST-RAID-Driver https://downloadcenter.intel.com/download/24779/Intel-Rapid-Storage-Technology-Intel-RST-RAID-Driver
strip6
thanks for responding. may be i haven't made my query clear. I already have RST installed (v 9.5.4.1001). i just want to update it. As for my system provider my laptop is more than 3 years old and my system manufacturer has all but stopped supporting it that's why i had to come here. i already tried installing it from the link provided but it says "platform not supported". What might be reason for that error? Can i manually update the inf file?
strip6
Following is the system info as generated by intel RST.
System Report
System Information
OS name: Microsoft Windows 7 Home Premium
OS version: 6.1.7601 Service Pack 1 7601
System name: VAIO-VAIO
System manufacturer: Sony Corporation
System model: VPCEA16FG
Processor: GenuineIntel Intel64 Family 6 Model 37 Stepping 2 2.4 GHz
BIOS: BIOS Date: 09/23/09 11:58:43 Ver: 08.00.10, Sony - 20100720
Intel® Rapid Storage Technology
Kit installed: 9.5.4.1001
User interface version: 9.5.4.1001
Language: English (India)
Intel AHCI controller: Intel(R) 5 Series 4 Port SATA AHCI Controller
Number of SATA ports: 3
Driver version: 9.5.4.1001
ISDI version: 9.5.4.1001
Device Information
Disk on port 0
Port location: Internal
Status: Normal
Serial number: W77033M5
Model: ST1000LM014-1EJ164
Firmware: SM25
System disk: Yes
Password protected: No
Disk data cache: Enabled
Native command queuing: Yes
SATA transfer mode: Generation 2
Physical sector size: 3072 Bytes
Logical sector size: 512 Bytes
Disk on port 1
Status: Normal
Serial number: UJ15 224228
Model: MATSHITADVD-RAM UJ890AS
Firmware: 1.00
System disk: No
Disk data cache: Disabled
Native command queuing: No
SATA transfer mode: Generation 1
Physical sector size: 0 Bytes
Logical sector size: 0 Bytes
Empty port
Port: 5
Port location: External
Hans_B_Intel
