Rapid Storage Technology
Intel® RST, RAID
2188 토론
NVMe SSD Firmware update fail using APIs of Intel® Rapid Storage Technology Private API
ykameoka
초급자
2,029 조회수
I'm developing a NVMe SSD's application tool to update firmware on Intel RST/VMD platform(Intel CRB board with VMD enabled, and RST driver enabled.). The application tool's code follows details  of Intel® Rapid Storage Technology Private API document. However the  IOCTL_SCSI_MINIPORT request with ControlCode=IOCTL_RAID_FIRMWARE (chapter 6)
returns fail status: FIRMWARE_STATUS_INVALID_PARAMETER (0x3), expected status is FIRMWARE_STATUS_SUCCESS(0x0). I also tried using IOCTL_SCSI_MINIPORT request with IOCTL_NVME_PASS_THROUGH (chapter 2), the request returns fail status: FIRMWARE_STATUS_ERROR(0x1). My NVMe SSD is NVMe* Drives and should be compatible to the Intel® Rapid Storage Technology Private APIs, could you please provide some support about this failure?
<Intel Confidential document removed>
레이블 (1)
  • i
0 포인트
4 응답
Alberto_R_Intel
2,003 조회수
ykameoka, Thank you for posting in the Intel® Communities Support.
In reference to this scenario, we will do further research on this matter in order to try to provide the answer to your questions or to point you in the right direction for the proper technical support. As soon as I get any updates, I will post all the details on this thread.
Albert R.
0 포인트
Alberto_R_Intel
1,974 조회수
Hello ykameoka, I just received an update on this matter.
While we are still working on this case, we just wanted to confirm:
Which hardware are you using, could you please provide the SSU report?
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-?product=91600
Is the issue related to Intel® RST or NVMe SSD Firmware update failure?
Could you please clarify the following:
-the&nbsp; IOCTL_SCSI_MINIPORT&nbsp;request with&nbsp;ControlCode=IOCTL_RAID_FIRMWARE (chapter 6)
-status:&nbsp;FIRMWARE_STATUS_INVALID_PARAMETER (0x3)
-using&nbsp;IOCTL_SCSI_MINIPORT&nbsp;request with IOCTL_NVME_PASS_THROUGH (chapter 2)
I can see that you shared a document that is confidential, if the statements above are related to that document, I can always send you an email for you to provide that information to us.
Albert R.
0 포인트
Steven_Intel
중재자
1,937 조회수
Steven G.
0 포인트
Steven_Intel
중재자
1,867 조회수
Since we have not heard back from you, we will close this thread. If you need any additional information, please submit a new question, as this thread will no longer be monitored.
Steven G.
0 포인트
응답
