Rapid Storage Technology
Intel® RST, RAID
2209 Discussions
Question about intel rapid storage
СC000
Hello. I created a backup of the system ssd drive using the intel rapid storage program chose raid 1, as a result, this partition was copied to the hdd but in addition I deleted all the data that was on the hdd. Perhaps as the return back by removing this the partition? What surprised me most, when creating raid 1 array, there was no warning that the data on the disk will be deleted. What you think is a huge disadvantage. On disk was 300 GB freely, so I and thought that on this free place backup and will create program, not would delete important data. Who knows as can be return back the former state of the high, write please. Thanks!
AlHill
You had a backup of your data before you started this venture, correct?
Doc
СC000
СC000
Если только сама программа перед созданием raid не создает её, что вряд ли
AlHill
Backups, with or without RAID, are always the responsibility of the user.
Doc
n_scott_pearson
I agree that they could use better warnings, but this is not something that the noobie (ok, naive user) should be playing with anyway.
Storozh
Mistakenly wrote the wrong way !
СC000
А как надо правильно?
СC000
What now? I ran the recovery through the r studio program and at this stage I have a list of folders selected by file extensions. There is no disk structure, I think it is overwritten by the first 120 GB, which just took a backup copy of the system ssd disk. At this stage, I have just this copy on the hdd, and the rest is empty space, it is 800 gigs...
n_scott_pearson
Now? Well, you will need to remove the drives from the array, but there is no guarantee that your data will still be present and accessible.
Sorry,
СC000
И что теперь? Я запустил восстановление через программу r studio и на этом этапе у меня есть список папок, выбранных расширениями файлов. Там нет структуры диска, я думаю, что он перезаписан первым 120 ГБ, который просто взял резервную копию системного ssd-диска. На данном этапе у меня есть только эта копия на жестком диске, а остальное пустое пространство, это 800 гигабайт...
СC000
Как я могу удалить его? В меню intel rapid при загрузке заходите и там удаляете raid раздел? У меня также есть скриншоты загрузки, можете отправить?
n_scott_pearson
Use the paperclip icon to upload and attach your screenshots. Unfortunately, it is 12:25 AM and I am an old fart who needs his sleep. I will have to look at this in the morning...
СC000
_20200109_211932.JPG Вот меню этой программы и там есть раздел delete raid и reset disk non raid. - Вот это?
n_scott_pearson
That is correct; choose option 3 and then select both drives. Again, I cannot guarantee that this won't further corrupt the contents of these drives.
...S​
СC000
Спасибо. - Я постараюсь. А что может быть хуже того, что уже произошло?) Я сделал восстановление данных через программу и расширения, которые я нашел файлы, но так как структура папок перезаписана, очень неудобно найти то, что мне нужно сейчас!
Storozh
Здравствуйте ! А что же вы собственно хотели получить с помощью программы по восстановлению данных R-Studio ? Сейчас примерно опишу что у вас получилось. Вы выбрали сделать резервную копию системного SSD-диска объёмом 120 гигабайт с помощью Intel Rapid Storage Technology(IRST). И выбрали в качестве приёмника второй диск объёмом 1 терабайт. IRST взяла скопировала посекторно весь системный SSD-диск в начало 1 терабайтного. Файловая система, в которой хранятся записи о файлах и папках(их именах и объёме, и местонахождении содержимого(тела)), начинается с 3-х гибибайт от начала раздела(если раздел создавался ОС, а не с помощью какой-нибудь акронисовой поделки). И, соответственно, саму файловую систему "накрыло" содержимым 120 гигабайтного SSD-диска; и какую-то часть содержимого файлов тоже, которые находились в первых 120 гигабайтах. Поэтому программа восстановления данных R-Studio и не может показать структуру диска - папки и файлы, которые были на 1 ТБ диске, т.к. "родная" файловая система перезаписана содержимым 120 гигабайтного SSD. Она показывает только что смогла найти с помощью RAW-сканирования, т.е. по заголовкам файлов, рассортированное по типам. И даже такое сканирование(RAW) не вариант чтобы восстановить хоть что-то, т.к. если на 1 терабайтнике ни разу не делалась дефрагментация, то получите в основном "огрызки" файлов: внутри "тела" файла через какой-то промежуток может находиться не то что должно. Я съязвлю, но скажу, что в данном случае вам может помочь только машина времени, чтобы вернуться в прошлое - других вариантов не вижу. А на будущее всё-таки постарайтесь осознать такую вещь: ЕСЛИ НЕТ РЕЗЕРВНОЙ КОПИИ ДАННЫХ, ТО ОНИ(ДАННЫЕ) НИКАКОЙ ЦЕННОСТИ НЕ ПРЕДСТАВЛЯЮТ И СОБСТВЕННО НЕ НУЖНЫ. И резервных копий должно быть как минимум ДВЕ и именно ЦЕННЫХ данных. Причём вторая копия должна находиться территориально как минимум в другом городе, а ещё лучше в другой стране на случай пожара, наводнения, землетрясения и т.д. 😀.
СC000
ясно, дефраг не было)
