Rapid Storage Technology
Intel® RST, RAID
2199 Discussions
RAID notifications - Intel Optane Memory and Storage Management
PeterV
We have set up a RAID10 on the ASUS Z490-A mainboard holding an Intel 10900K CPU, running Windows Server 2019.
Several of these systems will be deployed at a customer.
The old IntelRST app, that had an e-mail function, can't be installed ("This Platform is not supported").
and this new Intel Optane Memory and Storage Management does not have any 'remote' notification options.
I've tried looking for events in the EventLOG after pulling a drive out, but there are no error events.
What is best practice; what is the recommended way to make these servers remotely notify when RAID errors occur?
The developers can't just expect everybody to log onto these servers manually every week, do they?
M_J
Hi
Maybe this helps you guys as well, I have found out that you can actually use  the last version of Intel RST which is V17.8.0.1065 as merher pointed out above even on newer driver versions, at least it works in that way on Dell OptiPlex 7080.
So do like this:
1.Install the new version of the intel raid driver , and you will probably get that new crap application which we all hate installed.
2.Uinstall that crap application ( right click and choose uninstall on start menu, as it are not in regular add / remove programs).
3. Download and extract RST-Win10-17.8.0.1065.zip
4.Run RST\SetupRST.exe from the folder.
5.Success!
/Mats
M_J
Hi
So do like this:
5.Success!
/Mats
M_J
Not at work now so can't compare archive size, but seems very familiar yes.
I used the latest driver itself from Dell support pages ( via Dell command update ) , but the rapid storage application from this archive yes, according to my post above
M_J
Hi
At work now and I confirm its exactly that archive we use the RST program from.
/Mats
PeterV
Thank you for your reply! Unfortunately that is not the solution for us.
I tried every version there is to download.
M_J
Hi
And you have the RAID setup working with the new crap application? As I mentioned before you should use the new driver and only the application from the mentioend archive.
So when after uninstalling the crap application and installing the RST  only from the  RST-Win10-17.8.0.1065.zip via RST\SetupRST.exe  you got that error message?
Sorry then I can't help you.
PeterV
YES IT WORKS!!!
Folks, I can say that this 17.8.0.1065 version works with our setup!
It is something I didn't think would be compatible with our hardware so I did NOT try it before.
Thanks SO MUCH to both M_J and GrEEnbYte for pointing out the version and for supplying the exact link!
I will paste the link again:
Intel® Rapid Storage-Technologie (RAID) für Intel® NUC 9 Extreme Notebooks Kits
https://downloadcenter.intel.com/de/downloads/eula/29838/Intel-Rapid-Storage-Technologie-RAID-f-r-Intel-NUC-9-Extreme-Notebooks-Kits?httpDown=https%3A%2F%2Fdownloadmirror.intel.com%2F29838%2Feng%2FRST-Win10-17.8.0.1065.zip
ClaytonLee
This is a very exciting development!
I will give this a shot asap and add my 2c to the discussion.
PeterV
Unfortunately.... that installer does not accept Windows Server 2022.
Again: "This platform is not supported".
Searching for a new solution!
