Rapid Storage Technology
Intel® RST, RAID
2208 Discussions
RST Does not detect three of my drives windows 10
RRich18
I am running on the asus p8z77 v-Premium motherboard it is a z77 motherboard i am running version 13.1.0.1058 RST. i have 2 pny ssd drives. one is 120. other is 240. and a one terabyte wsd black drive. i have one other ssd. which is a Kingston 54 gig ssd. it does come up i also have a wsd windows device issue it seems emanating from all three of these drives i have checked in my bios i am in achi mode with hot plug off my windows is up to date and write caching is enabled i did notice all three drive are picked up as removable in properties not set to quick removal and the Kingston drive is not i have downloaded all asus drivers for my windows and have them installed please lend a hand i will post some pics
KL2
Valued Contributor I
Are you sure the problematic SSDs / HDDs are not plugged into the Marvell SATA controller?
Page 1-7 (# 9 in the diagram): http://dlcdnet.asus.com/pub/ASUS/mb/LGA1155/P8Z77-V_PREMIUM/E7356_P8Z77-V_Premium.pdf http://dlcdnet.asus.com/pub/ASUS/mb/LGA1155/P8Z77-V_PREMIUM/E7356_P8Z77-V_Premium.pdf
Hello TheBastard,
You best support will be your system manufacturer, even though there are Intel components in your system, your computer manufacture may have altered the feature and customized your system, however, you can try the following:
Try reinstalling the chipset driver from your motherboard manufacturer website
https://www.asus.com/Motherboards/P8Z77V_PREMIUM/HelpDesk_Download/ https://www.asus.com/Motherboards/P8Z77V_PREMIUM/HelpDesk_Download/
NOTE: This link is being offered for your convenience and should not be viewed as an endorsement by Intel of the content, products, or services offered there.
Are those drives visible in the BIOS, try to set the BIOS to default settings, press F9 on your keyboard when you're in the bios and then press F10 to save all changes.
Try to reconnect your HDDs on your SATA ports, make sure they are not connected on the Marvel port as Gize2 is saying or try formatting your HDDs.
Ivan.
