Rapid Storage Technology
Intel® RST, RAID
2197 Discussions
RSTe (NVMe) driver keeps crashing
Basdf
Windows Server 2012 R2
Intel P3700 2.5" drives. 2x in RAID1, 7x in RAID5
RSTe version 4.5.0.2125
This has happened on two different systems at two different times. Windows bluescreens, does a memory dump, and restarts. Error is:
DRIVER_IRQL_NOT_LESS_OR_EQUAL (IaRNVMe.sys)
Nothing gets logged into the event viewer and I cannot find any log files of it.
Basdf
System is a Supermicro 2028U-TN24R4T+
All drivers and firmware are up to date.
Drive bays 1-9 are populated.
All parts are on the Supermicro supported hardware list.
I do have a 16GB memory dump that Windows created, 1.69GB zipped.
Hello brian89gp,
We understand that you're looking for assistance in resolving your system crashes being reported as triggered by our Intel® RSTe NVMe RAID Driver.
In order for you to receive the best support possible, we will be moving your thread over to our /community/tech/rapid-storage-technology Rapid Storage Technology Support Community.
Please continue monitoring your thread for updates.
Carlos A.
Hello brian89gp:
Thank you very much for letting us know that information.
As you mentioned above, all the hardware and the RSTe version being used are fully compatible with each other.
Based on that, we will review this case in order to try to find a possible solution to fix this problem.
As soon as I get any updates, I will post all the details on this thread.
Any further questions, please let me know.
Alberto
Hello brian89gp:
I just wanted to check if the information posted previously was useful for you, if you were able to get in contact with Supermicro and if you have further questions on this matter?
Alberto
Hello brian89gp:
After reviewing your case, I just wanted to let you know that since the Intel® C612 chipset that the board has is a server chipset, in that case in order to get support for this product you just need to get in contact with Supermicro directly, they should be able to provide further assistance with the RSTe (NVMe) driver:
http://www.supermicro.com/products/system/2u/2028/SYS-2028U-TN24R4T_.cfm http://www.supermicro.com/products/system/2u/2028/SYS-2028U-TN24R4T_.cfm
Supermicro's phone number: (408) 503-8000
Supermicro's support site: https://www.supermicro.com/support/index.cfm https://www.supermicro.com/support/index.cfm
Let me apologize for any inconvenience.
Alberto
