Rapid Storage Technology
Intel® RST, RAID
2189 ディスカッション
Raid-0 rebuilded into raid-1
tipompier
ビギナー
1,877件の閲覧回数
I had two Raid-0 disks set by built-in Raid controller on a motherboard (Asus P5W-DH with Asus EZ Backup = Intel matrix storage).  I've changed my motherboard and forgot that my disk was in raid-0.  With the other motherboard, Intel matrix storage tell me "rebuild" state in the bios, but in raid-1!  In windows I have lunch the intel rapid strorage software.  The rebuild have progressed to 100%, after I was invited to do a initialization and a verify, what I did...  So now my disks are in RAW mode.
So I want to know what the rebuild and a initialization process did to my disks ?  Is my disks have the same data now or I have a little hope that only the library was faulty ?
I used some recovery software, I can see my wanted files, but everytime the files are corrupted.
Thx for your help!  Sorry for my poor english!
0 件の賞賛
6 返答(返信)
AndrewG_Intel
従業員
1,871件の閲覧回数
Hello tipompier
We have sent you a private message to gather and update contact information.
Andrew G.
Esteban_D_Intel
モデレーター
1,864件の閲覧回数
Hello tipompier,
Based on the description provided, you would need to delete the whole volume and rebuild the RAID, we would recommend the creation of the RAID from scratch pressing Ctrl + I upon boot.
For that, please follow the article with all the steps to create a RAID volume.
Set Up a System with Intel® Matrix RAID Technology
In case that Ctrl + I is not pulling the console for the management of the RAID volume, you might need to contact the motherboard manufacturer for indications, if that is the case most likely the console will be within the BIOS.
Unfortunately, as you know, RAID 0 provides no-fail tolerance or redundancy as the information is “Stripped” between the disks that form the RAID volume and that could be the reason why the recovery tool is showing all the files as corrupted.
Please give it a try and if you have an update please let us know.
Esteban D.
tipompier
ビギナー
1,858件の閲覧回数
Hi,  Thx for the answer,
So to be sure, you sugest me to delete my Raid-1 volume in Intel matrix raid tech. and create a new raid-0 volume ?  Is this will format my disks ?
Before doing this, is any way to check if my disk have the sames blocks ? In other words, is my disks are clones or not ?  If they are clones, it will be the end
Thx!
n_scott_pearson
スーパーユーザー
1,857件の閲覧回数
When the RAID0 array was rebuilt as a RAID1, the stripes from the first drives will have been copied over top of the stripes on the second drive. If I understand correctly, this will have effectively wiped out every other stripe. I would think that the logical drive would have been a corrupt mess (I was actually amazed at how much you could see; I would have expected the file system's structure to not be intact either). This means that the contents are going to be a total loss, unfortunately.
If you remove the RAID1 array and create a new RAID0 array over it, it isn't going to affect much of the contents of the drive, but when you get into Windows, it will want to initialize the (logical) drive and then have you create partition(s) on it. If the contents weren't a goner already, then this will likely be the last straw.
AndrewG_Intel
従業員
1,842件の閲覧回数
Hello tipompier
We are checking this thread and we would like to know if the previous information was helpful to clarify your concerns or if you have additional inquiries. Please do not hesitate to contact us back.
Andrew G.
AndrewG_Intel
従業員
1,814件の閲覧回数
Hello tipompier
We have not heard back from you so we will proceed to close this thread. If you need further assistance please post a new question.
Andrew G.
返信
