Rapid Storage Technology
Intel® RST, RAID
2190 Discussions
Received a notification after restarting my PC that said "Data on one or more volumes is protected from a disk failure" Is this an error message and are there any steps I can take to fix it?
AGoch
n_scott_pearson
Yes, it is an error message. It usually is produced when a disk drive being used in a RAID (typically RAID1) array has failed. Check the Intel Rapid Storage Technology Console for more information. You likely need to replace the failed drive.
Hope this helps,
AGoch
How do I check the Rapid Storage Technology Console?
Adam
mgyori
Hi Scott,
I don't understand your response here.  In this thread: https://community.intel.com/t5/Rapid-Storage-Technology/Notification-of-quot-Data-on-one-or-more-volumes-is-protected/td-p/1198829
you say this exact same message is nothing to worry about at all.
But in this thread you say it's a serious problem.
I'm getting this message and it certainly sounds like one of the redundant drives in my RAID is failing, but when I do an exhaustive verify on both of my Raids, it returns that everything as fine.
Michael
Computerdienst
To me it just sounds like an informational message: „Hey man, your drives are protected.“
Nothing to me here that sounds like an error. Especially if there is no error to be seen in the GUI.
n_scott_pearson
I am not sure I understand your question. You install the Intel RST software and driver package on your system and then it is there.
