Rapid Storage Technology
Intel® RST, RAID
2190 Discussions
Recover RAID 1 after failure
Not applicable
I have an HP Elitedesk 800 with Intel Rapid store Technology.
The machine rebooted an now says no operating system.
There is a RAID 1 mirror with 2 1tb mechanical drives.  The array says it is in a "Failed" state.  But I removed the drives and connected them to another machine using an externally attached USB disk adapter.  Both drives showed the normal Windows booth disk folders.
I also ran the local hardware test on the Hp machine and both drive passed.
The issue seems to be the ARRAY is corrupted, but not the disk.
How do I recover the system to a running machine?
Thanks in advance.
DeividA_Intel
Thank you for posting on the Intel® communities. I understand you are having issues with your laptop.
1. Can take pictures of the errors?
2. What is the BIOS version of your laptop?
3. Are you using this computer as a server?
4. What is the version of the Intel® Rapid Storage Technology (Intel® RST) tool and driver?
5. Are you able to see the disks at the BIOS?
Deivid A.
DeividA_Intel
Hello.
Were you able to check the previous post and get the information requested? Please let me know if you need more assistance.
Deivid A.
DeividA_Intel
We have not heard back from you, so we will close this inquiry. If you need further assistance or if you have additional questions, please create a new thread and we will gladly assist you.
Deivid A.
