Rapid Storage Technology
Intel® RST, RAID
Recreate RAID volume
MC5
I was using my MSI motherboard for RAID 1. But I did something stupid, I chose the option to "Reset Disks to Non-RAID". Now both disks show up as RAW in Windows. Is there any way to recover the files on these drives? These mirrored drives are used for data, OS is on another drive. I've tried using some data recovery software to scan the drives, but it only found .swf files (these are not the actual files on the drives)...
Thank you!
Hello superman1122,
Thank you for contacting Intel Communities.
Please check the following links and let me know how it goes:
https://support.microsoft.com/en-us/help/2261358/a-volume-may-show-up-as-raw-in-disk-management-after-you-extend-the-partition,-but-chkdsk-shows-the-file-system-as-ntfs A volume may show up as "raw" in disk management after you extend the partition, but https://support.microsoft.com/en-us/help/2261358/a-volume-may-show-up-as-raw-in-disk-management-after-you-extend-the-partition,-but-chkdsk-shows-the-file-system-as-ntfs chkdskhttps://support.microsoft.com/en-us/help/2261358/a-volume-may-show-up-as-raw-in-disk-management-after-you-extend-the-partition,-but-chkdsk-shows-the-file-system-as-ntfs shows the file system as NTFS
http://www.tomshardware.com/forum/280932-32-hard-drive-recovery RAW hard drive recovery
*NOTE: These links are being offered for your convenience and should not be viewed as an endorsement by Intel of the content, products, or services offered there.
I would recommend testing in one of the drives as you had RAID 1.
JC
Hello superman1122,
I was reviewing this thread and I wanted to know if you need further assistance.
If so, please don't hesitate in replying to this post.
JC
