Rapid Storage Technology
Intel® RST, RAID
2056 Discussions
Reset to device, Device RaidPort0, was issued, iastorAC 129
Emre
Hello
I have Predator Helios 300 PH317-53 noteebook. It's keep freezing with iastorAC 129. When notebook freeze sometimes about 20 second later returning to normal but usually it's shutdown and reboot itself(usually without bsod sometimes with bsod).How can I fix this problem?
Thank you for your help.
- <System>
  <Provider Name="iaStorAC" />
  <EventID Qualifiers="32772">129</EventID>
  <Version>0</Version>
  <Level>3</Level>
  <Task>0</Task>
  <Opcode>0</Opcode>
  <Keywords>0x80000000000000</Keywords>
  <TimeCreated SystemTime="2021-03-02T18:23:38.6774213Z" />
  <EventRecordID>2280</EventRecordID>
  <Correlation />
  <Execution ProcessID="4" ThreadID="7400" />
  <Channel>System</Channel>
  <Computer>DESKTOP-NLNU39O</Computer>
  <Security />
  </System>
- <EventData>
  <Data>\Device\RaidPort0</Data>
  <Binary>0F001800010000000000000081000480010000000000000000000000000000000000000000000000000000000000000002000000810004800000000000000000</Binary>
  </EventData>
  </Event>
Emre
Hello
Here it is another minidump.
Ellie93
Did you manage to fix the problem?
I've been having similar problems on an HP laptop
Emre
I have a portable hdd and I installed windows 10 on it. Right now I'm booting my laptop on portable hdd. It's been 2 week and there is no blue screen error or NoBootable Device warning but when I boot the laptop on ssd the same issue happining.Laptop showing blue screen and after that No Bootable Device warning. So I think ssd causing the issue.
David_G_Intel
Thank you for your the information provided. We are working on this request, the updates will be posted on the thread.
David G.
Intel Customer Support Technician
David_G_Intel
Thank you for the information provided. The engineering team working on this request requires a full crash dump, those files are about +1.2GB and need to be uploaded using google drive or other cloud services. We'll be waiting for the files.
David G
Emre
Hello
I already attached memory.dump before.
Here it is.
https://www.mediafire.com/file/uhg80suyw1jrz2l/MEMORY.rar/file
But befor you check this.Let me explain what I did to solve the issue. I have a portable hdd and I installed windows 10 on it. Right now I'm booting my laptop on portable hdd. It's been 2 week and there is no blue screen error or NoBootable Device warning but when I boot the laptop on ssd the same issue happining.Laptop showing blue screen and after that No Bootable Device warning. So I think ssd causing the issue.
David_G_Intel
David G.
David_G_Intel
Thank you for the information provided, we will proceed to close the case since your problem is resolved and we will continue to work on improvements for the software.
David G.
Pirate
Hey @Emre, @David_G_Intel,
Did any of you find a solution for this. I face this same issue on my predator helios 300(Predator PH315-52).
It happens while gaming.
SSD active time goes to 100% and no reads or writes happens.
Windows just freezes for a while and laptop reboots(sometimes with bsod).
Some times when rebooting it says "No storage device found" but boots again if you press the power button after waiting 2-3 seconds.
Event viewer has the same message as op.
Tried switching from RST premium to ahci, same thing happens only difference being in the event log.
Tried with different versions of windows including latest. All drivers are updated to latest.
Help would be much appreciated.
Emre
Yes finally problem solved.
Technical Service replaced the motherboard
I recommend you try with different ssd or try plug your ssd other ssd port.
And if it doesn't work ask for help from technical service.
