Update:
After using CrystalDiskInfo and carefully reading SMART of each disk. I found the culprit. One of the disk is having 400,000+ Read Error Rate. Seem like my disk is failed.
I am deleting attached file to preserve my privacy now.
I have RAID10 setup running with 4 disks. There was a blackout occur and after the power has restored. My RAID setup has been stuck on verifying and repairing at 31%. I tried reboot and re-perform verifying and repairing, the progress is gradually increase then it stopped at 31% again. I also tried to only trigger only the array verification without repair, yet it still stuck at 31%. The SMART reading indicate that all disks are healthy. It would be easy if the system tells me one of the drive has failed. But this, I have no clue what to do next.
I have attached Intel RST System Report along with Intel SSU Scan Information file for diagnostics.
Please help.
Hello KobiCurry
Thank you for posting on the Intel️® communities. Please confirm if the issue was resolved after replacing the drive or if you still need assistance.
David G
Hello KobiCurry
David G
David G.
I can confirm that after I replaced the drive and rebuild the array everything works normally.
We are glad to know you found a solution, since the thread is solved we will close it now.
David G
