Rapid Storage Technology
Intel® RST, RAID
2223 Discussions
SSD with RAID 1 HDD Configuration
Nordik
I do own a Dell XPS8300 desktop PC. Originaly, the PC came with a RAID 1 configuration (RST). After an HDD failure, I plan to reinstall the OS and Applications on a SSD and add a new HDD to replace the defective RAID1 HDD. Since the PC will now boot on AHCI (PC can only boot on AHCI or RAID), can I still use a RAID 1 configuration for the 2 DATA HDD?
n_scott_pearson
If you want to use a SSD as your Windows Boot/System device and have another pair of HDDs in a RAID1 array, you should leave the BIOS configured for RAID.
Install Windows onto the SSD as you normally would (it will be setup to use AHCI automatically) and then you can create the new RAID1 array across the two HDDs. Note that, if this SSD is a M.2 NVMe SSD, you should ensure that the BIOS is (also) configured to boot using UEFI.
Nordik
Hi Scott!
Thank you for your response! Actually my BIOS only support AHCI or RAID (Dell XPS8300 Circa 2011). The SSD would be a Samsung EVO 860 Sata. I will try the proposed solution. Any recommandation on the RST version I should be using?
Best Regards
Alberto_Sykes
Hello Nordik, I just wanted to check if the problem with the Intel® Rapid Storage Technology application still persists and if you need further assistance on this matter?
Albert R.
A Contingent Worker at Intel
Alberto_Sykes
Hello Nordik, Since I have not heard back from you, we are closing the case, but if you have any additional questions, just reply back or post a new question.
Albert R.
