Rapid Storage Technology
Intel® RST, RAID
2188 Discussions
Secondary Samsung 980 PRO NVME SSD only detected during Intel RST driver installation?
PdG
Greetings Support,
I recently purchased an Alder Lake system, but have problems with enabling the secondary NVME SSD (Samsung 980 PRO 2TB) in Windows 11. The drive is detected and visible in the BIOS, but does not show in Windows (or only for a very limited time).
The weird thing is: when installing the Intel RST driver, at around 22% into the process, the secondary NVME SSD is detected by Windows 11 (a notification appears) and useable for a little while. During that time I can copy files to it and the drive operates as normal. When the RST driver installation finishes, even before reboot, the drive is ejected again and unavailable in Disk Management again. I can reproduce this behaviour.
Hardware
Motherboard: ASUS ROG STRIX Z690-I GAMING WIFI
CPU: 12th Gen Intel(R) Core(TM) i5-12600K
RAM: 2x16GB Crucial DDR5
NVME SSD #1: Samsung SSD 980 PRO 2TB -> connected to CPU, boot drive
NVME SSD #2: Samsung SSD 980 PRO 2TB -> connected to Chipset -> problem drive
SATA SSD: Samsung SSD 870 QVO 4TB -> not relevant here, but added for completeness
Software
Windows 11 PRO -> fully updated
Intel_RST_Driver_Software_V19.0.0.1067_WIN10_WIN11_64-bit -> downloaded from ASUS (Z690-I) Product Support page
Some observations
- Both NVME SSD are technically working correctly. I've switched the drives multiple times and installed Windows on both of them. I've also run self tests and used Samsung Magician for checking the health and performance.
- One time, after switching the drives in the motherboard M2 slots, the secondary drive (connected to chipset) was actually active for a short while. During that time I managed to update the firmware of both drives, but shortly after the secondary drive was ejected again.
- During the Intel RST driver installation, the Windows Event Viewer generates the following warning: "The application \Device\HarddiskVolume3\Windows\System32\DriverStore\FileRepository\iastorvd.inf_amd64_815480839574a92b\RstMwService.exe with process id 3560 stopped the removal or ejection for the device PCI\VEN_8086&DEV_467F&SUBSYS_86941043&REV_00\3&11583659&0&70.
Process command line: C:\Windows\System32\DriverStore\FileRepository\iastorvd.inf_amd64_815480839574a92b\RstMwService.exe" -> this seems important, but I'm not able to determine what this exactly means.
I've attached the SSU scan for review. If necessary, I can also make a video of the driver installation, which shows the timeframe the drive is available and the notification of Windows 11 that a new hardware component is detected.
Could you please assist? I'm very confused about this behaviour. It doesn't seem to be a hardware failure, as I can force the drive to become active for a short while (by installing the RST driver)... maybe a firmware issue?
Thank you.
DeividA_Intel
Hello PdG,
1. Does the issue occur with the Intel driver?
2. Did the drives work before with your ASUS ROG STRIX Z690-I GAMING WIFI? If so, when did the issue start?
3. Did you notice the issue with Windows 10?
4. Have you checked with Asus for further steps and recommendations?
Deivid A.
PdG
Hi Deivid,
Thanks for your quick reply.
In regard to your questions:
1. The Intel RST driver obviously has an effect on the secondary NVME SSD. During the installation process of the RST driver, the SSD becomes visible in Windows and I can access it. When the installation process finishes, the SSD gets "ejected" again.
2. As this is a new build (all components are newly bought), the issue started right away. Both SSD drives work as expected in the primary (M.2_1) slot (even before installing the RST driver). I've switched both of them several times and installed Windows on them also several times. In the secondary (M.2_2) slot, the drives only function as expected during installation of the Intel RST driver (repeatable) and once it did function correctly for a couple of minutes right after I've switched them around (not repeatable, I think).
3. I just installed Windows 10 to verify if the problem also occurs on that platform. I can now confirm the problem occurs on both Windows 11 and Windows 10. Also the Intel RST driver shows the exact behaviour (drive becomes visible during installation).
4. Not yet, but I am about to.
- I'm very curious what happens around the 22% (progress) mark during the RST driver installation, because something triggers the drive to become active/visible. I think it is worthwhile to know and even thought about disrupting the driver installation process at that specific time to see if it has a positive effect...
- The Event Viewer warning also seems interesting and can be linked to the RST driver, although I don't know how to interpret it: "The application \Device\HarddiskVolume3\Windows\System32\DriverStore\FileRepository\iastorvd.inf_amd64_815480839574a92b\RstMwService.exe with process id 3560 stopped the removal or ejection for the device PCI\VEN_8086&DEV_467F&SUBSYS_86941043&REV_00\3&11583659&0&70.
PdG
DeividA_Intel
Hello PdG,
Thank you for the information provided
Deivid A.
workparty
thanks for this information
DeividA_Intel
Hello PdG,
In order to help you further, please try the Intel® Rapid Storage Technology Driver Installation Software with Intel® Optane™ Memory (10th and 11th Gen Platforms) driver.
- Driver: https://www.intel.com/content/www/us/en/download/19512/intel-rapid-storage-technology-driver-installation-software-with-intel-optane-memory-10th-and-11th-gen-platforms.html
Please let me know if the issue persists.
Deivid A.
PdG
Hi Deivid,
I managed to get it solved.
The problem was caused by an extremely "fragile" seating process of the M2 stack on the ASUS Z690-I motherboard. Reseating the M2 stack 15-50 times solves the issue... somehow. Other users reported the same problem. More information can be found here: https://rog.asus.com/forum/showthread.php?127294-ASUS-ROG-STRIX-Z690-I-GAMING-WIFI-secondary-NVME-(M2_2)-issue
I still can't explain why the Intel RST driver managed to get the SSD visible and working in Windows during installation of the driver (even with an "incorrectly connected" M2 stack), but I've spent enough time on this already and will leave it at that...
Thanks for your support!
PdG
DeividA_Intel
Hello PdG,
Thanks for the information provided, I do appreciate that you shared how you solved the issue. This will help anyone that may be facing the same issue.
I will close this thread, however, you can open a new one in case you need further support.
Deivid A.
PitKoz
I guess now we have time to sort out Samsung 990 pro M.2 NVMe
the config is:
CPU: Intel Core i9-11900K - 107%
GPU: Nvidia RTX 2080-Ti - 164.3%
SSD: Samsung 990 Pro NVMe PCIe M.2 2 TB - 387.7%
HDD: Seagate ST2000VM003-1CT164 2 TB - 88%
HDD: WD WD10EURX 1 TB - 46.3%
HDD: Seagate ST2000VM003-1CT164 2 TB - 57.4%
HDD: WD WD10EURX 1 TB - 33.3%
HDD: Crucial NVMe CT2000P3SSD8 M.2 2 TB
RAM: Corsair CMT64GX4M4K3600C18 4x16GB - 114.4%
MBD: Gigabyte GA-Z590 VISION D
And Intel driver for this board (the newest one) does not see the 990 MVMe.
It is a boot drive.
I have discovered it when was migrating my Raid 1 disks and making check in
IRST UI.
Samsung NVMe is connected directly to CPU,
in 4gen x 4 PCIex,
But completely not visible to drivers for IRST.
Can not check condition nor real connection to MBD.
Crucial NVMe is OK and showing ... a bit different to real parameters
it should be PCIex gen 3.0 x 4
OK, what can we do with this case?
So far, for now, nothing on Samsung nor Gigabyte about it ...
