Rapid Storage Technology
Intel® RST, RAID
Something updated
Jason0937
 Since something was updated in my computer this never was show me when i turn on my computer (4 years with this appearing) so i think something is wrong i went to the bios and my settings were all disconfigurated what should i do
n_scott_pearson
The most likely cause of this is the SATA Mode parameter being reset to AHCI. Go into BIOS Setup and reset this parameter to RAID.
Can you say more about what happened that you are seeing this BIOS Configuration reset? Also, what board was this happening with?
Jason0937
Done i put it in raid
It activated a m.2 optane genie to and appear all hotplugs disabled
And still all the same initializing without appear that screen
Motherboard z270 gaming pro carbon
n_scott_pearson
It sounds like you need to go into BIOS Setup and reset the entire BIOS configuration to defaults. Don't forget to set the SATA Mode (back) to RAID before saving the configuration.
