- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Report is below with details:
I have a raid 5 volume with 4 disks. Since they are Green drives, the drives normally have issues and I have to mark it as normal and then rebuild. Anyways, recently, I lost one drive and now I'm unable to rebuild. It keeps saying the drive is missing, no matter what. Therefore, I am unable to rebuild.
I bought a brand new drive and replaced it (exact same drive), but it just won't rebuild, no matter what I do. I am posting this from my secondary PC. My primary PC is ICH10R if that makes any difference.
All 5 drives are there and working just fine, but for some reason it won't read them properly and says it's "failed". It refuses to rebuild and just stays in the "failed" state with a missing drive. I've tried marking the drives as spare and available. As you can imagine, I have some extremely important and sentimental files on this RAID. Any help is GREATLY appreciated. I had a backup solution that died a few months ago
System Report
System Information
OS name: Microsoft Windows 7 Professional
OS version: 6.1.7600 7600
System name: Sameer-PC
System manufacturer: System manufacturer
System model: Maximus Formula
Processor: GenuineIntel Intel64 Family 6 Model 15 Stepping 11 2.394 GHz
BIOS: American Megatrends Inc., 1403
Intel® Rapid Storage Technology
Kit installed: 10.6.0.1002
User interface version: 10.6.0.1002
Language: English (United States)
Intel RAID controller: Intel(R) Desktop/Workstation/Server Express Chipset SATA RAID Controller
Number of SATA ports: 6
RAID option ROM version: 8.7.0.1007
Driver version: 10.6.0.1002
ISDI version: 10.6.0.1002
Device Information
Available space: 0 GB
Disk data cache: Enabled
Number of volumes: 1
Volume member: GrandCentral
Number of disks: 4
Array disk: WD-WCAVY3811045
Array disk: WD-WCAVY3641783
Array disk: WD-WCAVY3728931
Array disk: D-WCAVY3806666:0
Status: Failed
Type: RAID 5
Data stripe size: 64 KB
Write-back cache: Disabled
System volume: No
Initialized: Yes
Verification errors found: 0
Blocks with media errors: 0
Physical sector size: 512 Bytes
Logical sector size: 512 Bytes
Parent array: Array_0000
Number of disks: 4
Disk on port 0
Port location: Internal
Status: Normal
Type: Hard disk
Usage: Available
Serial number: WD-WCAVY3806666
Model: WDC WD20EARS-00S8B1
Firmware: 80.00A80
System disk: No
Password protected: No
Native command queuing: Yes
SATA transfer rate: 3 Gb/s
Disk on port 1
Status: Normal
Type: Hard disk
Usage: Array disk
Serial number: WD-WCAVY3811045
Firmware: 80.00A80
System disk: No
Disk on port 2
Status: Normal
Type: Hard disk
Usage: Array disk
Serial number: WD-WCAVY3641783
Firmware: 80.00A80
System disk: No
Disk on port 3
Status: Normal
Type: Hard disk
Usage: Array disk
Serial number: WD-WCAVY3728931
Firmware: 80.00A80
System disk: No
Disk on port 4
Status: Normal
Type: Hard disk
Usage: Available
Serial number: WD-WCAZAA974710
Model: WDC WD20EARS-00MVWB0
Firmware: 51.0AB51
System disk: No
SATA tran...
- 태그:
- Chipsets
- Controllers
- Intel® IO Controller Hub 10
- Intel® IO Controller Hub 9
- Intel® Rapid Storage Technology
- RAID
- Storage
링크가 복사됨
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Hi there!
A RAID 5 with "failed" status means that you need recreate your RAID structure by creating RAID from scratch. Unfortunately, the RAID BIOS does not offer recover options.
If you need to safe your data, you will need to contact a data recovery company.
Allan.
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Hi Bob,
Same thing for a RAID 5 volume. The RAID cannot be recovered if this is under failed mode.
