Hey Intel
I have a software RAID-1 on Windows 11 that is working great
The only issue is that I am running out of space,
Currently the Raid is comprised of two 4TB drives.
I would like to upgrade both to a new 14TB (two HDD both same 14TB Capacity and same brand)
Can you help me with the steps on how to upgrade both hard drives with the large capacity hard drives?
If you can provide step by step on how I would really appreciate it!
Hi @Sean_Mk,
Before upgrading, back up important data to an external drive or cloud storage to prevent loss. Monitor the RAID rebuild process, as it can take several hours. After upgrading, verify that all data is intact and accessible. Update RAID settings for the new drive sizes. Test your system for stability and performance to ensure everything works properly.
Here are the steps: Move a RAID 1 Volume to Larger Hard Drive
If you encounter any issues. please let me know so I can further assist you.
Randy T.
Hi @Sean_Mk,
Randy T.
Hi @Sean_Mk,
Randy T.
I got it and going to try it soon and post the results
Thank you so much
Hi @Sean_Mk,
Thank you for the update. I will now proceed with closing this thread for the meantime. Please note that it will no longer be monitored. Once you have completed the steps, you can update us by creating a new thread and referencing this one. This way, if you need further assistance, we can continue to help you.
Randy T.
