Rapid Storage Technology
Intel® RST, RAID
公告
2192 讨论
Upgrading my Bootable RAID1 Capacity with Optane Memory and Storage Management
RobertRexter
初学者
12,180 次查看
Not sure I am posting in the correct section...
I have Windows 11 Pro w/latest updates and have 2x SATA 512GB SSD’s in a RAID1 configuration as my boot and data drive (C:).  The computer is a Dell Precision Tower 3431.  There is only one array in this system and no other drives at all.
The computer has Secure Mode enabled and RAID option is set in the BIOS.  The software is Intel Optane Memory and Storage Management (Not the older Intel RST).
I would like to upgrade the size of my two drives from 2x SATA 512GB SSD’s to 2x SATA 1TB SSD’s.  These drives are connected to the motherboard SATA connectors.
I have seen the directions on how to do this for Intel RST but can’t find how to do this for Intel Optane Memory and Storage Management.
The directions I have for this procedure for “Intel RST” is below:
  1. Turn off the system and remove one of the drives.
  2. Replace it with a drive larger in capacity.
  3. Turn on the system and boot into Windows*.
  4. Open the Intel® Rapid Storage Technology user interface (Start > All Programs > Intel > Intel® Rapid Storage Technology).
  5. Click Rebuild to another disk.
  6. Select the newly added drive and click Rebuild.
  7. Allow the rebuild to complete.
  8. Restart the system and enter the Intel® Rapid Storage Technology option ROM by pressing CTRL+I when prompted.
  9. Click Reset Disks to Non-RAID.
Note
You may see a dialog box warning you of data loss. This warning does not apply to RAID 1; you will still be able to access your data.
  1.
  2. Click Yes to confirm.
  3. Click Exit and shut off the system.
  4. Remove the original (smaller) drive from the system. This will leave only the new (higher capacity) drive, acting as a single drive (it is no longer part of a RAID volume).
  5. Turn on the system and boot into Windows. You may need to change the drive priority in the BIOS.
  6. From within Windows, use the Windows computer management tools or a third-party partitioning software to resize the drive partition so that it uses the entire capacity of the drive.
  7. Turn off the system and attach the second large drive.
  8. Turn on the system and boot into Windows.
  9. Open the Intel Rapid Storage Technology user interface and click the Create icon.
  10. Follow the prompts to create a new RAID 1 volume. Your data will then be migrated from the single large drive to the new RAID 1 volume.
The directions for RST seem to apply but when it gets to the “steps 8 through steps 12” booting into the BIOS Legacy Option ROM with CTRL+I, I do not believe that this exists in Secure Boot and Optane Memory and Storage Management.
Would I have to go into the BIOS and disable Secure Boot then enable Legacy Option ROM to make CTRL+I work?
*** or ***
My hopes would be that I would be able to simply:
Remove one smaller SSD and replace with larger SSD, tell Intel Optane to rebuild the array.
After rebuild completes, remove the other smaller SSD and replace with larger SSD, tell Optane to rebuild the array again.
After rebuild completes, go into Windows Disk Management and resize the array to the new larger size.
Would this be a viable option or is there another way to do this?
For backing up prior to doing any of this, I will be using Acronis to make a full image of the array prior to attempting any of this.
Thanks for any help!
0 项奖励
1 解答
AlfredoS_Intel
主持人
7,434 次查看
Hi Robertrexter,
Thank you for waiting for our update.
Before attempting the below instructions, please ensure that you have saved backups of your data.
1. Showing Intel RST RAID 1 array in Normal Status.
2. Reboot in BIOS the go to (Advanced -] Add-in Config). Reset one of the drives in the RAID 1 array to non-RAID.
3. This will show in BIOS that the RAID array is "degraded".
4. The Boot screen prior to the Operating System splash screen will show "Abnormal status reported by Rapid Storage Technology UEFI driver.
5. Open Intel Optane Memory and Storage Management and it should show kkRAID array is Degraded.
6. The software should show  the driver that was removed from the array . Do not mark as spare
7. - Select the RAID array and click on "Rebuild to another disk".
8- Now select the drive to rebuild into then click "Rebuild".
9 - Now it will rebuild the RAID array. You need to wait for this process to finish.
10. After doing the Rebuild. Do the same for the other drive.
11. After doing the rebuild of RAID 1 array with now larger capacity drives, resize the volume using disk management tools like Windows Disk Management to extend the volume to utilize the additional space.
We look forward to your feedback regarding our post.
Alfred S
在原帖中查看解决方案
0 项奖励
23 回复数
AlfredoS_Intel
主持人
10,622 次查看
Hi Robertrexter,
Thank you for creating a thread in Intel Communities.
It is a good idea to confirm the steps that you gathered with us before attempting the configuration that you are after.
To accurately answer your questions, kindly provide the following information:
1. The Windows Operating System on your RAID Volume can be either a Legacy or UEFI version. We presume that it is most likely a UEFI version. Kindly let us know if we have a wrong presumption.
2. It would really help us if we can get more information about your system. Please download and run our Intel® System Support Utility from this page,. To run it, please press "Scan". After the scan is finished, click next and there will be a save button, giving you an option to save the logs to a text file, please do so and attach the file on your reply. You can refer to How to get the Intel® System Support Utility Logs on Windows* for instructions.
3. Are you comfortable in accessing your system’s BIOS configuration page? If yes, kindly check if you have an Intel RST UEFI option ROM like the one pictured on page 101 of this Intel Rapid Storage Technology User Guide. If you have a UEFI Windows installation, switching to Legacy just to access “CTRL and I” may be a very complicated process and may introduce Windows boot up failures.
Alfred S
0 项奖励
RobertRexter
初学者
10,610 次查看
Hello Alfredo,
Yes, my system is UEFI version.
Attached is my file from the Intel SSU scan.
Yes, I am comfortable accessing my BIOS.
I have an option in the BIOS to turn on Legacy Option ROM but it won't let me unless I disable SecureBoot.  Not sure I want to do that as I am concerned it may mess up the boot process.  I believe Dell configured the array in software mode with Intel Optane Memory and Storage Management when it was purchased.  The system does not have Intel RST installed.
Thank you.
0 项奖励
AlfredoS_Intel
主持人
10,597 次查看
Hi Robertrexter,
Thank you for the prompt response.
While I am waiting for your post in reply to our message, I was checking if your system has a preinstalled Intel RST UEFI Interface as this could be vital in successfully completing your planned upgrade, and I stumbled on this Dell Article, How to Access the RAID Controller Setup in UEFI Configured Computers. There is a column titled, “How to Access RAID BIOS in UEFI mode”. Kindly confirm if this is something that is possible on your system.
Alfred S
0 项奖励
RobertRexter
初学者
10,580 次查看
Hello Alfred,
I am able to access the Dell Intel RST UEFI interface through using F12 during bootup.
Screen shot attached.
0 项奖励
AlfredoS_Intel
主持人
10,556 次查看
Hi Robertrexter,
Thank you providing those information.
Please allow us some time to check on this.
We will get back to you as soon as we have updates.
Alfred S
0 项奖励
AlfredoS_Intel
主持人
10,390 次查看
Hi Robertrexter,
We are in the middle of our investigation and resolution finding process for the concern that you raised, and our engineers would like to obtain the following information that is vital for the investigation to move forward:
1) To confirm, you have mentioned that you will be creating backups for your image, do you already have a backup created? If not, please create a backup first before you try our suggestions.
2) You mentioned that Dell created the RAID 1 on the machine. When you took the system out of the box, do you already have RAID 1 preconfigured on the machine?
3) We need to confirm your system for accuracy purposes. Please confirm if this is your system model, https://www.dell.com/learn/us/en/45/shared-content_data-sheets_documents/dell-precision-3431-spec-sheet.pdf.
4) Since you can enter the Intel RST UEFI utility through F12, we need to know what options are available to you. Intel UEFI GUI maybe different across manufacturers, thus we need to check what features are available on the GUI. On the screenshot that you provided, please press enter on the “Array0…” that you have, then please provide a screenshot, so we will know the options available to you. Some configurations of the Intel RST have the increase size option, which will make it easier for you to obtain your planned upgrade, and we hope you have this option on your system.
We will wait for your answers.
Alfred S
0 项奖励
RobertRexter
初学者
10,325 次查看
Hello Alfred,
1) Yes, I have a backup of the system and would perform another backup prior to any implementations of your suggestions.
2) Yes, Dell pre-configured the RAID1 out of the box with the OS already installed.
3) Yes, my system is a Dell Precision Tower 3431 computer.
4) I attached a picture of the screen after hitting enter on the RAID1 array in the RAID UEFI GUI.
There does not seem to be any other option to resize the array, only delete it or go into the two individual drives and remove each from array.
Thank you
0 项奖励
AlfredoS_Intel
主持人
10,338 次查看
Hi Robertrexter,
I wanted to check if you had the chance to read the questions that we posted. Please let me know at your earliest convenience so that we can determine the best course of action to resolve this matter.
Alfred S
0 项奖励
AlfredoS_Intel
主持人
10,300 次查看
Hi Robertrexter,
Thank you for your response and providing more details regarding the issue,
We will continue checking this and the information that provided is invaluable to us.
Please allow us some time to check on this. We hope for your understanding regarding this
Alfred S
0 项奖励
AlfredoS_Intel
主持人
10,041 次查看
Hi Robertrexter,
Our engineers thoroughly checked your concern and they would like to ask additional information:
1. Did you try to contact Dell regarding your concern? Since they are the one who preconfigured the RAID, they may be the best channel to advise you how to apply your planned setup with minimal risk of data loss.
2. See volumeactions screenshot. Are there options under “Volume Options”? Can we get a screenshot?
3. See arrowoptions screenshot. Please expand the arrow in one of the SATA drives and kindly provide a screenshot.
We look forward to your reply post.
Alfred S
0 项奖励
RobertRexter
初学者
10,010 次查看
Hello Alfred,
No, I have not yet reached out to Dell for a solution for this.  I will attempt to do that as well.
I checked on the "Volume Actions" and it is not selectable as it is a category title only (for the Delete function).
The arrow option screenshot is included and will likely not offer anything of value, it is just a SATA port identifier and the drive description.
There are no other selectable options on that screen.
Thank you,
Bob
0 项奖励
AlfredoS_Intel
主持人
9,961 次查看
Hi Robertrexter,
We will continue checking this and the information that you provided is invaluable to us.
Please allow us some time to check on your concern. We hope for your understanding regarding this.
Alfred S
0 项奖励
RobertRexter
初学者
9,555 次查看
I think that solution would help very much if you could please attach that document. It might have the info and steps I need to deal with Intel Optane Memory and Management software for this RAID1 storage size upgrade.
Thank you!
0 项奖励
AlfredoS_Intel
主持人
9,414 次查看
Hi Robertrexter,
Please see our update.
Based on the spec sheet of the system. It appears that it has 3 SATA ports, but it also shows that it supports up to (1) M.2 PCIe SSD on motherboard slot and Up to (1) 3.5" SATA or (2) 2.5" SATA.
You have mentioned that you use 2 Micron 1300 SATA 512 GB in RAID1 but doing research, it shows it can either be regular SATA or M.2 SATA. We would like to ask are you using the SATA version or the M.2 SATA version. May we also know the exact model of the 1 TB drivers that you will use on the system?
Also, may we also ask what storage ports are available in your system?
Alfred S
0 项奖励
RobertRexter
初学者
9,380 次查看
Hello Alfred,
I am currently on vacation until after Labor Day.  I will not be able to obtain this info until I am back from vacation.  I request to keep the ticket open until then.
Thank you,
Robert
0 项奖励
AlfredoS_Intel
主持人
9,090 次查看
Hi Robertrexter,
Thank you for letting us know that you need more time.
We will follow up with you after Labor day.
Alfred S
0 项奖励
RobertRexter
初学者
8,810 次查看
Hello Alfred,
I was able to get into work before Labor Day.  Here is the information you were asking for:
It seems the drives inside the computer are two 2.5" Micron 1300 SATA 512MB drives in RAID1.
There are no M.2 drives installed in the system.
The RAID1 array is on SATA Ports 0 and 3.  There is a DVD-ROM drive in SATA Port 2.
There is no entry at all for SATA Port 1 in the BIOS.  I "believe" this is reserved for the M.2 slot since the photos show no SATA Port 1.
I have attached two photos of the BIOS drive config screens to help.
The drives I will be installing to upgrade/replace the two 2.5" Micron 1300 SATA 512MB SSD drives have changed.  I now have two 2TB drives to replace them.
They are two 2.5" Samsung 870EVO 2TB SSD drives.
Model Numbers for both drives are: MZ-77E2T0
Model Codes for both drives are: MZ-77E2T0B/AM
Thank you,
Robert
0 项奖励
RobertRexter
初学者
8,769 次查看
salma98670,
Yes, a guide for IOM&SM absolutely may be very helpful to me if you could attach it.
0 项奖励
AlfredoS_Intel
主持人
5,598 次查看
Hi Robertrexter,
We appreciate the time that you took out of your busy schedule to provide the latest information that we asked.
Alfred S
Intel® Customer Support
0 项奖励
AlfredoS_Intel
主持人
7,435 次查看
Hi Robertrexter,
Alfred S
0 项奖励
回复
