Rapid Storage Technology
Intel® RST, RAID
VROC journalling and RAID 1
Tom53
I have a Dell Precision 7920 and am using the on-board VROC controller to support 3 RAID-1 arrays using standard HDD drives. Is there any benefit in nominating an SSD as a journaling drive? Would the write speed of the SSD rather than the standard drives then be the limiting factor for write performance?
Many thanks for any advice.
Labels (2)
David_G_Intel
Hello Tom53
Thank you for posting on the Intel️® communities. Which operating system do you use?
David G
Tom53
Hi David,
I'm using Windows 11.
Best regards.
Tom.
David_G_Intel
Thank you for the update, can you please explain what you mean by "journaling drive"? Also, there should not be any write speed issues related to the SSD since it's an accelerated device by defect.
David G
Tom53
Hi David,
I was hoping to get that information from Intel! There is an option in the BIOS to set a drive as a spare or to set it as a journal drive. So what do you mean by "journal drive"?
What I would like it to do is allow an SSD to act as a fast non-volatile buffer of updates so I don't have to wait for data to be written to the slower spinning drives that make up my RAID 1 array.
Can it support that use-case?
Best regards.
Tom.
David_G_Intel
The best option in this case is to confirm with Dell what the Journaling drive will do for your Dell system. This computer runs on Intel server chipset and questions should be addressed by Dell directly.
David G
