Rapid Storage Technology
Intel® RST, RAID
2190 Discussions
how the iRST raid configuration menu in BIOS detect the NVMe drive supports RAID config or not?
jandr10
My NVMe drive is not getting detected under the iRST raid configuration menu in Asus BIOS. Wanted to know how the intel RST detects the drive as RAID configurable? Is there any settings in the NVMe drive to be changed?
thanks for the help.
Jinto: Thank you very much for contacting the Intel® Rapid Storage Technology communities. We will do our best in order to try to provide the information you are looking for.
In regard to your inquiry, yes, you will be able to set up a RAID configuration using NVMe's, but remember that you need at least two of them in order to build it. Now, the motherboard also needs to support the RAID, because before you create it, we will need to get into the BIOS and change the SATA mode to RAID for the system to work properly.
How many NVMe's are you using?
Which type of RAID are you planning to build?
We also wanted to verify some details about your system, please provide the SSU report for us to be able to do that, the application will allow you to save the report as a file, to attach a file, you must click "Use Advanced Editor" in the top right corner of the response box, then the "attach" option will appear in the bottom right corner of the response box:
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-
Any further questions, please let me know.
Alberto R
jandr10
Thanks for the prompt reply. I was using 2 NVMe drives and the BIOS the settings were changed to RAID. But the drives are not getting detected under the iRST RAID configuration window in BIOS. But the drives are showing up in Storage configuration and NVMe configuration in BIOS/Advance configuration menu. Inorder to get detected in RAID configuration window, does the drive need to advertise in identify controller/ identify namespace as the drive is RAID capable? Or is there any other settings in the drive preventing it from detected by the BIOS.
Jinto: You are welcome. For this type of scenario, we recommend to install the latest BIOS version for the board.
In regard to your inquiry, I looked on ASUS's web site for a guide or steps to build the RAID. I found some information that might not be related to your specific device, but the BIOS interface of your board might be similar as the one showing on the link below:
https://rog.asus.com/articles/guides/guide-install-m-2-pcie-ssds-in-raid-0-for-speed https://rog.asus.com/articles/guides/guide-install-m-2-pcie-ssds-in-raid-0-for-speed
Alberto R
jandr10
Hi Alberto,
Thanks for the support. Jus wondering if the Intel chipset Z170 support 4k supporting NVMe drives for the RAID configuration? or it supports only those NVMe drives that support 512b?
Hi Jinto: You are very welcome. I will do further research to confirm the information you are requesting, as soon as I gather any details I will post them on this thread.
Alberto R
jandr10
Thanks for getting back to me..
Just curious whether you managed to find any update on the Z170 RAID chipset 4k NVMe support?
Jinto: You are very welcome. We are still confirming that information. I will let you know as soon as I get all the details.
Let me apologize for any inconvenience.
Alberto R
Jinto: I just received an update in regard to your inquiry, and actually the Intel® RST tool does not support 4K native sector size devices. On the link below you will be able to see further details about this matter:
https://www.intel.com/content/www/us/en/support/articles/000005646/technologies.html https://www.intel.com/content/www/us/en/support/articles/000005646/technologies.html
Alberto R
