Rapid Storage Technology
Intel® RST, RAID
2213 Discussions
ich habe ausversehen ein Rate0 erstellt von meiner ssd 500gb und 2 terabyte HHD, wie kann ich das wieder zurücknehmen
WHild
ich habe mit Intel® Rapid Storage Technology ausversehen ein Rate0 erstellt von meiner ssd 500gb und 2 terabyte HHD, wie kann ich das wieder zurücknehmen
Hi Werner1710,
I understand you have created a RAID 0 with the Intel® Rapid Storage by accident and you would like to reset this configuration. Let me help you on this matter.
Please bear in mind the support we offer through this channel is only in English.
I regret to inform you that a recovery procedure is not possible with this type of RAID array. The RAID 0 configuration does not provide any kind of redundancy.
You will need to reset the configuration by Resetting the Array to Non-Raid and reinstall the operating system.
Please follow steps below:
Press < Ctrl >< i > when prompted to enter the Intel RAID Option ROM utility.
Use the up- and down-arrow keys to highlight Reset Disks to Non-RAID and press. < ENTER >
Use the up- and down-arrow keys to highlight the RAID volume to be reset and press < SPACE >. to select the disk(s).
Press < ENTER > to complete the selection.
Press < Y > to confirm the reset.
Note: When performing this operation, all data on the RAID drives is lost.
Hope this helps.
Allan J.
Hi Werner1710,
I was wondering if you were able to reset the array.
Allan J.
