Regarding the version 18.1.6.1039 of RST, could you help to confirm if optane can provide cache for Raid0 acceleration?since this version can provide the maintenance of RAID 0/1/5/10 according to the description you provided.
Look forward to your reply.
Hello Joyce77
Thank you for posting on the Intel️® communities. To provide provide the most accurate response we need more information on your current setup, please share with us the Intel® System Support Utility (Intel® SSU) results
- Download the Intel SSU https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-
- Open the application and select "Everything" click on "Scan" to see the system and device information. By default, Intel® SSU will take you to the "Summary View".
David G
David G.
David G.
![](/skins/images/7B0AB6865064EAE32B30EC9A4E94B48A/responsive_peak/images/icon_anonymous_message.png)
