Rapid Storage Technology
Intel® RST, RAID
2189 討論
your system is reporting one or more events and data may be at risk
erios
初學者
14,660 檢視
Hi I bought a laptop MSI Dominitator GT72s Pro G 2 months ago It was running fine but today I got a warning "your system is reporting one or more events and data may be at risk"
I checked and I couldnt find any error. I would appreciate if you could provide me a piece of advice
I noticed there was an update of Windows 10 last night not sure if this could trigger this message
Thanks a lot
0 積分
6 回應
erios
初學者
8,728 檢視
Below the system report
System Report
System Information
OS name: Microsoft Windows 10 Home
OS version: 10.0.10586 9200
System name: MSI
System manufacturer: Micro-Star International Co., Ltd.
System model: GT72S 6QE
Processor: GenuineIntel Intel64 Family 6 Model 94 Stepping 3 2.701 GHz
BIOS: American Megatrends Inc., E1782IMS.109
Intel® Rapid Storage Technology enterprise Information
Kit installed: 14.6.0.1029
User interface version: 14.6.0.1029
Language: English (Hong Kong SAR)
Driver version: 14.6.0.1029
ISDI version: 14.6.0.1029
Storage System Information
Controller name: Intel(R) 100 Series/C230 Chipset Family SATA AHCI Controller
Type: SATA
Mode: AHCI
Number of SATA ports: 4
Number of volumes: 1
Volume: Volume1
Number of spares: 0
Number of available disks: 1
Rebuild on Hot Plug: Disabled
Manufacturer: 32902
Model number: 41218
Product revision: 49
Direct attached disk: 15050EE022F3
Direct attached disk: 15050EE018D2
Direct attached disk: JS100X6202LRDS
Disk on Controller 0, Port 0
Status: Normal
Type: SATA SSD
Location type: Internal
System disk: No
Disk data cache: Enabled
Command queuing: NCQ
Transfer rate: 6 Gb/s
Model: Micron_M600_MTFDDAV128MBF
Serial number: 15050EE022F3
SCSI device ID: 0
Firmware: MU03
Physical sector size: 4096 Bytes
Logical sector size: 512 Bytes
Disk on Controller 0, Port 1
Status: Normal
Type: SATA SSD
System disk: No
Serial number: 15050EE018D2
SCSI device ID: 1
Firmware: MU03
Disk on Controller 0, Port 3
Status: Normal
Type: SATA disk
System disk: No
Model: HGST HTS721010A9E630
Serial number: JS100X6202LRDS
SCSI device ID: 3
Firmware: JB0OA3J0
ATAPI device on Controller 0, Port 2
Transfer rate: 1.5 Gb/s
Model: HL-DT-ST BD-RE BU20N
Serial number: M4BECFH5103
Firmware: 1.00
jbenavides
榮譽貢獻者 II
8,728 檢視
Hello garyjacques,
The information in the picture and the log does not provide details about reason for the error.
You might wanto to try Intel® Rapid Storage Technology version 14.8.0.1042 that can be found at the following location: https://downloadcenter.intel.com/download/25165/Intel-Rapid-Storage-Technology-Intel-RST-RAID-Driver Download Intel® Rapid Storage Technology (Intel® RST) RAID Driver
If Intel® RST does not show further details, the Windows® event logs might provide more information about the problem.
We noticed that you are not using any Intel® SSD's in your configuration, so we are forwarding this to the forums, this way the Intel® RST support community can provide further assistance if needed.
ddane
初學者
8,729 檢視
https://downloadcenter.intel.com/download/25165/Intel-Rapid-Storage-Technology-Intel-RST-RAID-Driver https://downloadcenter.intel.com/download/25165/Intel-Rapid-Storage-Technology-Intel-RST-RAID-Driver
"Page Not Found
We are sorry, there is no Intel.com page matching your request. The page may have been renamed, moved or is no longer available. Please verify the address you typed is spelled correctly. If you are certain that this URL is valid, please send us http://www.intel.com/feedback.htm feedback about the broken link.
If you are searching for a download, these would be the alternatives:
If the Download Center site is unavailable, it may be down for maintenance. We apologize for any inconvenience this may cause."
Allan_J_Intel1
8,729 檢視
Your computer is not currently on RAID mode, this is AHCI; it may be that you need to check data integrity of your drive by running diagnostic tool from the hard drive maker.
Allan.
ddane
初學者
8,729 檢視
"Page not found" for the last 3 versions (14.8.0.1042, 14.0.0.1143, 13.6.0.1002) from https://downloadcenter.intel.com/product/55005/Intel-Rapid-Storage-Technology-Intel-RST- Drivers & Software
Allan_J_Intel1
8,729 檢視
I have tested the link you posted and that is currently working.
Allan.
回覆
