Hello, Bakhytzhan.
Thank you for the picture.
I will contact you privately to continue with the warranty process.
Just for future reference for you an other users, it is better to contact us directly via private method (Phone, Chat or support portal) if you suspect that a warranty is required or you want to request warranty directly, instead of posting the request on the public forum.
I have also deleted the picture from the community thread, and the thread will also be closed.
Bruce C.
Thankyou for posting your question in Intel communities. We only provide support in English. I have translated your question below.
Hard disk error
Fixed on intel hard drive | ssk1t92021502x | 1.92t 2.5 sata 1dw s4510 | 4 | Error.
On the recommendation of service support, removed and re-inserted the problematic hard drive. didn't help.
Does this reflect your question correctly.
Thanks and Regards,
Praneeth Achanta
We have not heard back from you. Could you please provide an update on your issue?
Thanks & Regards,
Praneeth Achanta
Error on one of the “Intel” hard drives.
On the recommendation of service support, our engineer removed and reinserted the problematic hard drive. Did not help.
Please provide further advice on troubleshooting.
Hello, Bakhytzhan.
I received your ticket regarding this Intel SSD S4510, and I will be providing you with some information.
Can you please confirm if this SSD came preinstalled in your system?
If this is the case, can you please share the serial number of the SSD?
I will follow up on April 14th.
Bruce C.
I attached a photo of the problematic hard drive
[File deleted by admin]
Hello, Bakhytzhan.
Bruce C.
