Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
4933 Discussions
关于 Intel Xeon Silver 4310 内存类型的问题
thewoz
 Intel Xeon Silver 4310的内存类型支持2667Mhz,请问如果我配置服务器的内存为32G的DDR4 3200Mhz,会不会降频到2667,是不是没必要去配置3200Mhz的内存条呢?
n_scott_pearson
It really depends upon the motherboard and its BIOS. Some motherboards will automatically invoke the XMP settings and attempt to use them. Other motherboards will default to the maximum settings supported by the processor. Still other motherboards will default to the lowest settings (2133MHz). Most motherboards also provide a back-off capability so that, if a setting doesn't work (causes bus hang), the BIOS watchdog recovers and automatically drops to lower settings. This doesn't always work, of course, depending upon how the failure will manifest.
I remind you that using memory and XMP settings that take the speed above the maximum supported by the processor is considered a form of overclocking and could disaffect the lifetime of the processor and even void your warranty.
Hope this helps,
David_G_Intel
Hello thewoz
Thank you for posting on the Intel️® communities. This is a server processor, we will move this thread to the appropriate forum.
David G
