服务器重启以后找不到系统盘,设置了启动项后保存可以进系统,再次重启以后启动项就会自动变更,然后就找不到系统盘
Hello ,
I would like to indicate you that the supported language is English. Regarding your question, "The server is not booting up after restarting". Could you be so kind with start by gathering some information.
Could you please provide me the server system board.
RAID Controller been use.
BIOS Version on the system board and the if the RAID controller is a PCI Card.
System configuration.
CPU
Memory
HDD
RAID configuration
Thank you for the help.
If there is anything else we can help please feel free to ask.
Henry A.
Hello ,
I would like to indicate you that the supported language is English. Also, I will like to follow up and ask if you could send us the information requested before.
Henry A.
Hello ,
Henry A.
Topic Options
