Server Products
4991 Discussions
1-5-4-4 beep code in board S3420GPLC
Hi, good day. I connected a power supply Cooler Master mod RS-460-PSAR-J3 (460w) in server board S3420GPLC, but when I turn it on I heard a beep code 1-5-4-4. I tested without processor, if I put the processor the fans start work but they are reset. How can I solve the problem and if the power supply is wrong, which model is the correct?
Edward_Z_Intel
To power the board on you'll need to connect a 24-pin main power connector and a 8-pin CPU power connector. For power requirements, see the S3420GP http://www.intel.com/support/motherboards/server/s3420gp/sb/CS-030742.htm Technical product specification, section 10.3~10.4. I'd suggest you choose a chassis from the http://www.intel.com/support/motherboards/server/s3420gp/sb/CS-031016.htm Tested chassis list.
