why 5520vi with two xeon 5620 and 9 * 4GB kingston 1333 Mhz operate in 800 mhz ?
how to tune it to 1333 .
please help thank's.
Memory speeed is determined by the Processor QPI links and the memory population rules.
E5520 only supports 800Mhz and 1066 Mhz operation http://ark.intel.com/products/40200?wapkw=e5520 http://ark.intel.com/products/40200?wapkw=e5520
9 DIMMS is kind of a strange number to be populated.
Each processor memory is independent with a max of 6 DIMMS per processor.
On a E55xx processor, more than 1 DIMM per channal (blue slots only) will cause the memory to clock down Check the Users Guide pg 47
http://download.intel.com/support/motherboards/server/mfs5520vi/sb/mfs5520vi_user_guide1.pdf http://download.intel.com/support/motherboards/server/mfs5520vi/sb/mfs5520vi_user_guide1.pdf Pg 47
I don't see VI in the memory configuration tool, but WB is simular http://imct.intel.com/cfgview.aspx?id=546931 http://imct.intel.com/cfgview.aspx?id=546931
THank you for your attention to my problem.
All of the cpu's are 5620 no 5520.
Sorry, wrong link http://ark.intel.com/products/47925/Intel-Xeon-Processor-E5620-(12M-Cache-2_40-GHz-5_86-GTs-Intel-QPI http://ark.intel.com/products/47925/Intel-Xeon-Processor-E5620-(12M-Cache-2_40-GHz-5_86-GTs-Intel-QPI)
Same comment. Processor only supports 800 & 1033
http://imct.intel.com/cfgview.aspx?id=548758 http://imct.intel.com/cfgview.aspx?id=548758
![](/skins/images/DF2E495CEC88D713A66401CF495CD875/responsive_peak/images/icon_anonymous_message.png)
