Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
4613 Discussions
BMC didn't working
Good day.
I have a problem with BMC. We bought intel server with S2600CP motherboard. i configure bmc with using this instruction http://www.intel.com/content/dam/support/us/en/documents/motherboards/server/sb/g54899001_s2600cp_p4000cp_sg_rev14.pdf http://www.intel.com/content/dam/support/us/en/documents/motherboards/server/sb/g54899001_s2600cp_p4000cp_sg_rev14.pdf
I enter ip address via Intel®Active System Console for all interfaces (with different IP), and still can't connect to BMC web interface. How can I solve this problem?
Hello StanislavStryukov ,
You could try https://downloadcenter.intel.com/downloads/eula/26296/Intel-Server-Board-S2600CP-Firmware-Update-Package-for-EFI?httpDown=https://downloadmirror.intel.com/26296/eng/S2600CP_EFI_BIOS02060005_ME020107328_BMC0127r9958_FRUSDR111.zip Intel® Server Board S2600CP Firmware Update Package for EFI and if it does not solve the issue try the BIOS recovery instructions.
Additionally, please let us know which Bios and BMC versions do you have and also which ip are you trying in this case as default and what changes have you made in order to try different scenarios.
Caesar B.
We are wondering if you were able to try https://downloadcenter.intel.com/downloads/eula/26296/Intel-Server-Board-S2600CP-Firmware-Update-Package-for-EFI%3FhttpDown%3Dhttps%253A%252F%252Fdownloadmirror.intel.com%252F26296%252Feng%252FS2600CP_EFI_BIOS02060005_ME020107328_BMC0127r9958_FRUSDR111.zip Intel® Server Board S2600CP Firmware Update Package for EFI and if he BIOS recovery was needed.
Please let us know if at all possible which Bios and BMC versions do you have and also which IP address are you using as default and what changes were made.
Sincerely,
Caesar B.
You should be able to configure the BMC Web Console in the BIOS to be able to access using your web browser. It should not required to use the Intel Active System Console portal.
For more information you can refer to the following document.
http://www.intel.com/content/www/us/en/support/boards-and-kits/000006023.html?wapkw=rmm4 RMM4 User's Guide
Additionally, our Intel support team can provide side by side configuration if needed. Feel free to contact our http://www.intel.com/content/www/us/en/support/contact-support.html Technical Support Department for further guidance.
Dave A.
Hello StanislavStryukov,
Here is another article on how to configure your BMC Web Console. I hope this helps.
http://www.intel.com/content/www/us/en/support/server-products/000007913.html?wapkw=bmc+console How to Configure BMC for Remote Monitoring and Control for Intel® Server Board S2600 Family
Dave A.
David_A_Intel
Hello stanislavstrannik
I was wondering if you were able to configure the BMC of the system after all? Feel free to post again if further assistance is needed.
