Server Products
4798 Discussions
Bios update error on S2600CP: a file incompatible with target
BNode
I've received a S2600CP4 motherboard from server disassembly.
This motherboard is working with 2xE5-2660v2 and 32GB of RAM (8x4GB Samsung 1600MHz registered).
Ubuntu OS installed without an issue.
I tried to build a home server, but the motherboard didn't start with a RX560 videocard. Neither with RX480.
Looks like it won't start when something is connected to PCI-E.
I decided to update the bios.
During the BMC update all ended up successfully.
But when I executed a command ''UpdateBIOS.nsh", I've got a message:
"Error: A file in the update package is incompatible with the target".
It seems that the current bios is incorrect.
I'v tried the next bios versions:
02.02.0002
02.04.0003
02.05.0004
02.06.0005
02.06.0006
The result is always the same.
Please advise!
Boris
P.S.
I'm attaching the photos of the motherboard, the current bios version and the update error.
Hello BorisN,
It's certainly weird that different BIOS update packages are giving you this consistent error.
I would like you to try using the Online Flash Utility (OFU). You can download it from the following URL: https://downloadcenter.intel.com/download/26990/Intel-One-Boot-Flash-Update-Intel-OFU-Utility?product=61088. https://downloadcenter.intel.com/download/26990/Intel-One-Boot-Flash-Update-Intel-OFU-Utility?product=61088.
This will allow you to perform the BIOS installation while been online on the OS. Pretty much I would like you to try from this alternate method to see if the error persist.
Please keep me updated
Jose H.
BNode
Hello Jose,
I've tried to do what you've suggested. No success...
OS used: CentOS 7.4
The "Online Flash Utility" utility installed correctly, after the needed dependencies.
It displayed the current bios version on the motherboard and the version of the bios in the update file.
But the command "flushupdt -u /flushupdt.cfg" returned an error.
Please look at the photos I'm attaching to this message.
What else can I do in order to update the bios?
Boris
Hello BorisN,
I will recommend trying an older BIOS version. Maybe the previous one or two back.
Also, please tries a different USB key to do the BIOS update.
And if the problem persists will recommend trying to do the BIOS update with minimum Hardware. One CPU, one or two memory stick and no HDD
Henry A.
BNode
Hello Henry!
What is the earliest bios for this motherboard that supports V2 processors?
I wouldn't want to update the motherboard with bios that doesn't support my processors.
Boris
BNode
I tried to update with version 02.01.0002 with 1 CPU onboard, 1 memory stick and another usb flashdrive.
No success!
The errors are the same as in my first and the second posts.
Hello BorisN,
Lets try an older BIOS version like 01.02.0003 from following URL: https://downloadcenter.intel.com/download/21184/Intel-Server-Board-S2600CP-Family-Firmware-Update-Package-for-IDA-Intel-OFU-and-WinPE https://downloadcenter.intel.com/download/21184/Intel-Server-Board-S2600CP-Family-Firmware-Update-Package-for-IDA-Intel-OFU-and-WinPE-
If it returns an error about downgrade not allowed try the following: In order to downgrade from this BIOS version, you must use the recovery jumper method.
Please let us know the outcome.
Jose H.
BNode
Hi!
I've tried it already.
Never got an error about downgrading. Only the same error as in previous posts.
Recovery jumper method didn't work - the motherboard refuses to start when I switch the jumper to position 2-3 from 1-2.
Hello BorisN,
Could you please pull up the System Event Logs using this tool https://downloadcenter.intel.com/download/26988/System-Event-Log-SEL-Viewer-Utility https://downloadcenter.intel.com/download/26988/System-Event-Log-SEL-Viewer-Utility
and share them with us so we can take more in depth look?
Jose H.
Hello BorisN,
Where you able to pull up the requested logs?
If you have further questions don't hesitate to contact back.
Jose H.
BNode
Hello!
No, I wasn't.
It seems that what I need is a flashing util that ignores tge current bios version, and jast flushes the new version without checking for compatibility.
Can you provide this util?
Hello BorisN,
I think that unfortunately such a utility doesn't exist unless 3rd party modified. The BIOS version compatibility check up is a safety feature to prevent downgrade flashing which will permanently damage the board.
You could attach the SN and PBA # of the board or call us directly at https://www.intel.com/content/www/us/en/support/contact-support.html# @10 https://www.intel.com/content/www/us/en/support/contact-support.html# @10 since is possible that your board might need to be replaced.
Jose H.
BNode
Hello Jose,
Here's the S/N and PBA:
Boris
Hello BorisN,
After checking the warranty status of this board we found that it is currently out of warranty. Unfortunately this issue seems like and actual hardware failure and the next step will be to find a replacement board.
Let us know if you have further questions.
Jose H.
TArda
I cannot do bios update on Intel server (P4308CP4MHGC) board S2600CP4 and chassis P4308XXMXXMHG-C and bios version SE5C600.86B.99.99.X032 from 7/25/2011. I tried all versions of bios but without any success.
TArda
I cannot do bios update on Intel server (P4308CP4MHGC) board S2600CP4 and chassis P4308XXMXXMHG-C and bios version SE5C600.86B.99.99.X032 from 7/25/2011. I tried all versions of bios but without any success. Please help me.
