Server Products
4653 Discussions
Blade System zeigt einen Fehler - PS Slot # 4 Output Voltage: Upper Critical sensor threshold asserted
ASach
Hello 00923388,
Is it possible to retrieve this info from CU in the near future?
Jose H.
Hello 00923388,
In order to better understand the issue you are having could you please include the following info:
  • Server, chassis, board model
  • Troubleshooting steps already performed (PS reseat, swap, etc)
  • System logs
  • Current BIOS version
Its possible this could be an intermittent issue and could be resolved by reseating or swapping the PS. If the issue follows the PS its possible a hardware issue that will require the PS to be replaced. In such a case this server is a bit old and its possible that it is out of warranty so the PS replacement won't be covered.
Please let us know the outcome.
Jose H.
Intel Customer Support
Hello 00923388,
Do you have any updates abut this?
Let me know
Jose H.
ASach
This server is at our client's site, so I do not have any information yet
Hi there!
We understand sometimes it is difficult to work on a server environment right away. What we can do in this case is that we can have your client contact our http://www.intel.com/content/www/us/en/support/contact-support.html# @9 Intel Support Team at your best convenience.
David A.
Hello 00923388,
Jose H.
