Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
4657 Discussions
s1200sps fan speed too high
TChan37
how to control the fan speed on s1200sps?
Hello Tom,
Regarding your question, "Fans running at high speed on a S1200SPS".
This is normally because one or more fans are nor running properly or the BIOS and BMC have not synchronized with the fan setup.
If there is anything else we can help please feel free to ask.
Henry A.
TChan37
Hi Henry,
Thanks for your support, yes i solved after update the bios.by the way, what is FRU / SDR?
Tom Chan
Hi there!
FRU/SDR means Field Replaceable Unit/ Sensor Data Record. The FRU portion will display information about the system and will allow you to edit some of the fields such as Asset Tag, Part Number, Serial Number, etc for your own inventory purposes among other reasons.
The SDR will have the proper threshold settings and other parameters. This will allow the system to understand how slow or how fast the fans should run.
You can find more information about these at the following location.
http://www.intel.com/content/dam/support/us/en/documents/motherboards/server/sb/updating_frusdr_on_epsd_server.pdf How to Update FRUSDR for Optimum Server Performance
David A.
Hello Tom,
This is a follow up, regarding case 02719322. We would like to know if the troubleshooting we provided you was useful in fixing your issue. Is further assistance required on this case? Please let us know if there is anything else we can help or if we can proceed on closing the case.
Henry A.
Hello Tom,
Henry A.
Hello Tom,
Henry A.
