As the introduction for quickassist 8950, quickassist 8950 can run compression function at 24Gbps.
I have adjust the compression level to level 1, and packetsize bigger than 1M. Inst num set to max (2).
The throughput is 14Gbps for compression and 20Gbps for decompression, what should I do for this situation to achieve 24Gbps in compression ?
The CPU we use is Intel(R) Xeon(R) Silver 4214 CPU @ 2.20GHz,with 12 cores in total.
Type of PCH is C622. The base board we use is X11DPG-OT-CPU.
Another funtion (encryption) can be runned as 50Gbps, same as the introduce.
Our main code calls some functions in sample_code to generate original data, compress and print result. The functions we used are getCompressionInstanceMapping, createPerfomanceThreads, startThreads and waitForThreadCompletion.
Hi @Alex_Li ,
Thanks for your additional information. I will move this forum to the proper Server queue.
Jaime L.
![](/skins/images/7B0AB6865064EAE32B30EC9A4E94B48A/responsive_peak/images/icon_anonymous_message.png)
