Server Products
4909 Discussions
Cannot config embeded RAID1 in S5000VSASASR - Please advise
I have a server S5000VSASASR with:
Aptio Setup Utility > Main
- Flatform ID S5000VSA
- System BIOS
Version (blank)
Build Date (blank)
- Processor
Intel(R) Xeon(R) CPU E5410 @ 2.33 GHz (x2)
- Memory
Size 4GB
- HDD
SAS 300GB 15KRpm (x2)
I cannot config RAID 1 (mirror) for 2 HDDs but dont know why
when I boot by CDROM to install OS (win server 2k3), server said that cannot find HDD. (see attachment)
will you help me? thank alot
First thing to try is always going to be, update the Firmware.
I'm a little confused that the version and build date strings are empty, my guess is that the BIOS is corrupted.
thanks alot Jason
will you give me some document to upgrade firmware for S5000VSASASR?
I seached but cannot find useful one.
Binh.
Hello Binh,
There is a *lot* of firmware for serverboard S5000VSA. The best advice I can give you is this:
1) search support.intel.com for S5000VSA
2) filter search by firmware in far right category
3) sort results by latest by pressing "status"
4) download the Firmware update package for DOS (unless you have the Intel Deployment Assistant CD)
(here is where you decide which hardware you have)
5) download all the relevent firmware packages, if you have the hardware it's for, get it.
6) read the release notes from all the packages to decide on what order to flash the various firmwares in
7) carry out flashing firmwares following discoveries of step 6
I'm sorry I can't be more specific, but there are some things that I wont know since I don't have your server on my bench.
Jason
Thank Jason,
I will try your advise tomorrow. hope it work
Binh.
