Server Products
4842 Discussions
Catlow Platform Power Delivery Test Plan confirm
IversonHuang
Hi Sir:
We will use Intel Catlow 95W, Raptor Lake-E Processor (Catlow Platform) for MB develope.
But I don't know the CPU and  DDR5 test plan revision.
Case1.CPU test plan
MVP9.1 or IMVP9.2 ?
622198_IMVP9p1_Volt_Reg_Valid_Plan_Rev2p1
644954_IMVP9p2_Volt_Reg_Valid_Plan_Rev1p4
Case2.DDR5 test plan
DDR5 Memory Power Delivery Test Plan number?
Please help me to confirm.
Thank you.
Iverson
BrusC_Intel
Hello, IversonHuang.
Thank you for posting on the Intel Community Support forums for Intel Server Systems.
I have not been able to identify the correct support area for your inquiry based on the description of this request, so please let me know the following:
1. Is this the same support channel (forum) that you usually use to submit this type of inquiry?
2. Do you (or someone else at your company) have access to Intel Premier Support (IPS)?
3. Have you tried reviewing other forum sections that could be more closely related to your inquiry? For example:
https://community.intel.com/t5/Processors/bd-p/processors
https://community.intel.com/t5/Developer-Software-Forums/ct-p/developer-software-forums
I will follow up on June 22nd in case we do not hear from you.
Bruce C.
IversonHuang
Hi Bruce:
Due to I don't have IPS premissions,so I had check my Intel PAE about this.
The PAE had check my question and quickly response to me.
I think this problem had closed.
Thank you.
Iverson
BrusC_Intel
I'm really glad to hear that.
The thread will be closed right now, and it will no longer be monitored by Intel support, but if you require any type of assistance from Intel in the future, just open a new thread, or contact us using any of the available support methods:
- https://www.intel.com/content/www/us/en/support/contact-intel.html
Bruce C.
