Server Products
4874 Discussions
CentOS 6.6 Intel SRCSAS18E
JWise5
I have been running an intel mobo with hardware RAID and 6 x 1TB Drives for about four years. The server stopped booting a few weeks ago and I am trying to resurect it and if possible salvage the data. It was not even showing up in POST cycle as a controller, so I moved it to another board I had around and it shows up, but still not working correctly. The original system was running CentOS 5.x and controller moved to new system running CENTOS 6.6
Issue: RAID SRCSAS18E RAID 5 Volume not showing up. Cannot do "ctrl+G" from POST stage (it pauses for about 45seconds during post). OS driver installed as well as CLI and web tool but controller does not show up to web tool, and when I issue command to re-flash (likly it would be an upgrade as I don't recall last time I did a firmware flash on it) it does not give me very useful response.
Hardware:
[root@titan1 ~]# lspci
00:00.0 Host bridge: NVIDIA Corporation C55 Host Bridge (rev a2)
00:00.1 RAM memory: NVIDIA Corporation C55 Memory Controller (rev a1)
00:00.2 RAM memory: NVIDIA Corporation C55 Memory Controller (rev a1)
00:00.3 RAM memory: NVIDIA Corporation C55 Memory Controller (rev a1)
00:00.4 RAM memory: NVIDIA Corporation C55 Memory Controller (rev a1)
00:00.5 RAM memory: NVIDIA Corporation C55 Memory Controller (rev a2)
00:00.6 RAM memory: NVIDIA Corporation C55 Memory Controller (rev a1)
00:00.7 RAM memory: NVIDIA Corporation C55 Memory Controller (rev a1)
00:01.0 RAM memory: NVIDIA Corporation C55 Memory Controller (rev a1)
00:01.1 RAM memory: NVIDIA Corporation C55 Memory Controller (rev a1)
00:01.2 RAM memory: NVIDIA Corporation C55 Memory Controller (rev a1)
00:01.3 RAM memory: NVIDIA Corporation C55 Memory Controller (rev a1)
00:01.4 RAM memory: NVIDIA Corporation C55 Memory Controller (rev a1)
00:01.5 RAM memory: NVIDIA Corporation C55 Memory Controller (rev a1)
00:01.6 RAM memory: NVIDIA Corporation C55 Memory Controller (rev a1)
00:02.0 RAM memory: NVIDIA Corporation C55 Memory Controller (rev a1)
00:02.1 RAM memory: NVIDIA Corporation C55 Memory Controller (rev a1)
00:02.2 RAM memory: NVIDIA Corporation C55 Memory Controller (rev a1)
00:03.0 PCI bridge: NVIDIA Corporation C55 PCI Express bridge (rev a1)
00:06.0 PCI bridge: NVIDIA Corporation C55 PCI Express bridge (rev a1)
00:07.0 PCI bridge: NVIDIA Corporation C55 PCI Express bridge (rev a1)
00:09.0 RAM memory: NVIDIA Corporation MCP51 Host Bridge (rev a2)
00:0a.0 ISA bridge: NVIDIA Corporation MCP51 LPC Bridge (rev a3)
00:0a.1 SMBus: NVIDIA Corporation MCP51 SMBus (rev a3)
00:0a.2 RAM memory: NVIDIA Corporation MCP51 Memory Controller 0 (rev a3)
00:0b.0 USB controller: NVIDIA Corporation MCP51 USB Controller (rev a3)
00:0b.1 USB controller: NVIDIA Corporation MCP51 USB Controller (rev a3)
00:0d.0 IDE interface: NVIDIA Corporation MCP51 IDE (rev a1)
00:0e.0 RAID bus controller: NVIDIA Corporation MCP51 Serial ATA Controller (rev a1)
00:0f.0 RAID bus controller: NVIDIA Corporation MCP51 Serial ATA Controller (rev a1)
00:10.0 PCI bridge: NVIDIA Corporation MCP51 PCI Bridge (rev a2)
00:10.1 Audio device: NVIDIA Corporation MCP51 High Definition Audio (rev a2)
00:14.0 Bridge: NVIDIA Corporation MCP51 Ethernet Controller (rev a3)
01:00.0 PCI bridge: Intel Corporation 80333 Segment-A PCI Express-to-PCI Express Bridge
01:00.2 PCI bridge: Intel Corporation 80333 Segment-B PCI Express-to-PCI Express Bridge
02:0e.0 RAID bus controller: LSI Logic / Symbios Logic MegaRAID SAS 1068
06:08.0 VGA compatible controller: Matrox Electronics Systems Ltd. MGA 1064SG [Mystique] (rev 02)
06:0a.0 Ethernet controller: Intel Corporation 82544EI Gigabit Ethernet Controller (Copper) (rev 02)
[root@titan1 ~]# lspci -vv
Subsystem: Intel Corporation RAID Controller SRCSAS18E
Control: I/O- Mem+ BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping+ SERR- FastB2B- DisINTx-
Status: Cap+ 66MHz+ UDF- FastB2B- ParErr- DEVSEL=medium >TAbort- SERR-
Interrupt: pin A routed to IRQ 16
Region 0: Memory at cfef0000 (32-bit, prefetchable) [size=64K]
Region 2: Memory at cfdc0000 (32-bit, non-prefetchable) [size=128K]
[virtual] Expansion ROM at cfe00000 [disabled] [size=32K]
Capabilities: [c0] Power Management version 2
Flags: PMEClk- DSI- D1+ D2- AuxCurrent=0mA PME(D0-,D1-,D2-,D3hot-,D3cold-)
Status: D0 NoSoftRst- PME-Enable- DSel=0 DScale=0 PME-
Capabilities: [d0] MSI: Enable- Count=1/2 Maskable- 64bit+
Address: 0000000000000000 Data: 0000
Capabilities: [e0] PCI-X non-bridge device
Command: DPERE- ERO- RBC=512 OST=4
Status: Dev=02:0e.0 64bit+ 133MHz+ SCD- USC- DC=bridge DMMRBC=1024 DMOST=4 DMCRS=16 RSCEM- 266MHz- 533MHz-
Kernel modules: megaraid_sas
[root@titan1 CmdTool2]# dmesg |less
scsi 2:0:0:0: Direct-Access ATA Hitachi HTS72322 FCDO PQ: 0 ANSI: 5
ata4: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
ata4.00: ATA-8: WDC WD2500BEKT-60PVMT0, 01.01A01, max UDMA/133
ata4.00: 488397168 sectors, multi 16: LBA48 NCQ (depth 31/32)
ata4.00: configured for UDMA/133
scsi 3:0:0:0: Direct-Access ATA WDC WD2500BEKT-6 01.0 PQ: 0 ANSI: 5
ata6: SATA link down (SStatus 0 SControl 300)
megasas: 06.803.01.00-rh1 Mon. Mar. 10 17:00:00 PDT 2014
megasas: 0x1000:0x0411:0x8086:0x1001: bus 2:slot 14:func 0
megaraid_sas 0000:02:0e.0: enabling device (0080 -> 0082)
ACPI: PCI Interrupt Link [AXV7] enabled at IRQ 16
alloc irq_desc for 16 on node -1
alloc kstat_irqs on node -1
megaraid_sas 0000:02:0e.0: PCI INT A -> Link[AXV7] -> GSI 16 (level, low) -> IRQ 16
megasas: Waiting for FW to come to ready state
sr0: scsi3-mmc drive: 40x/40x writer cd/rw xa/form2 cdda tray
Uniform CD-ROM driver Revision: 3.20
sr 0:0:1:0: Attached scsi CD-ROM sr0
STARTING CRC_T10DIF
sd 2:0:0:0: [sda] 488397168 512-byte logical blocks: (250 GB/232 GiB)
sd 3:0:0:0: [sdb] 488397168 512-byte logical blocks: (250 GB/232 GiB)
sd 2:0:0:0: [sda] Write Protect is off
sd 2:0:0:0: [sda] Mode Sense: 00 3a 00 00
sd 2:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
sd 3:0:0:0: [sdb] Write Protect is off
sd 3:0:0:0: [sdb] Mode Sense: 00 3a 00 00
sd 3:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
sda:
sdb: sdb1 sdb2
sd 3:0:0:0: [sdb] Attached SCSI disk
sda1 sda2
sd 2:0:0:0: [sda] Attached SCSI disk</...
Silvia_L_Intel1
Hello Penguinpages, thanks a lot for posting your question at Intel communities.
I would like to inform you that I have moved your post to the Server Community at the following URL /community/tech/servers https://communities.intel.com/community/tech/servers
David_A_Intel
We have done http://www.intel.com/support/motherboards/server/srcsas18e/sb/CS-022722.htm validation to Red Hat Operating System up to 5.0 Update 3. My concern is that if the RAID controller is not initializing properly you might not be able to access the volume.
I would probably disconnect the data cable from the RAID controller and see if you can access the RAID BIOS (Ctrl+G) without the drives. You might as well want to try the firmware update with the drives disconnected.
JWise5
I will try unplugging the drive connections and see if I can get into / RAID BIOS.
I did also note your comment about "Tested to CentOS 5.3" but the website does not RHEL (CENTOS) 6 drives... hense why I moved it to a system which had CENTOS 6.6 already running so I could use that and avoid driver / base load os issues. https://downloadcenter.intel.com/SearchResult.aspx?lang=eng&keyword=srcsas18e+ https://downloadcenter.intel.com/SearchResult.aspx?lang=eng&keyword=srcsas18e+
Please validate that CentOS 6.x is valid.
MR_Linux_drv_v6.705.07.00.tgz
Supported RAID Controllers
SRCSAS18E*,
Package Information
Driver Version = 6.705.07.00
Driver update for RHEL 5.11, RHEL 6.6, SLES 12
JWise5
I know it has been several weeks on this thread but I have been plodding away on this. I have tried every way I can think of toe resurect this card. 1) Rule out USB keyboard not sending Ctrl+G by digging out old PS2 2) removing all drives from SATA ports 3) Unpluging all devices from motherboard that could interupt bus 4) disable all components in motherboard that could interupt 5) Try two different motherboards. 6) Pull cache upgrade off card to see if it would boot without cache (though this just ended in the card not even showing up on POST cycles)
I spent $500+ on this card only a few years ago... so I am really trying not to give up on it. Any other suggestions?
David_A_Intel
I believe you have exhausted all possible troubleshooting steps to bring the controller back to function properly. I would recommend contacting our http://www.intel.com/p/en_US/support/contactsupport Intel® Customer Support team for a proper follow up of this situation.
