Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
4543 Discussions
Compatability version of BIOS and version of Intel Rapid Storage Manager
MKaa
hi community
i have the problem that my intel storage manager shows all sata hdd's in raid 1 and raid 5 are broken.. (the hdd's are brand new!!)
what can i do? maybe it's possible, the compatability from the bios version and from the intel rapid storage manager version is wrong? according to the hardware raid manager shows that all hdd's are working correct!
i have the following hardware:
Systeminformation:
OS: Microsoft Windows Small Business Server 2011 Standard
Serverboard Modell: Intel S2400GP
BIOS-Version: Intel Corp., SE5C600.86B.01.06.0002.110120121539
Intel Rapid Storage-Technologie (Enterprise)
User Interface Version: 3.6.0.1094
Intel Controller: SATA (AHCI)
SATA-Ports Count: 6
Version of RAID-Extensions-ROMs: 3.2.0.1022 (the version 3.2.0.1016 is compatible with the above-named BIOS-version?! have found this under "http://downloadmirror.intel.com/21934/eng/BIOS_01.06.0002_ReleaseNote.txt http://downloadmirror.intel.com/21934/eng/BIOS_01.06.0002_ReleaseNote.txt")
Driver-Version: 3.5.1.1008
ISDI-Version: 3.6.0.1094
i'm on the edge of despair have searched many hours under intel.com vainly..
would be grateful about each answer can help me gp
many thanks!!
maknausd,
See the http://download.intel.com/support/motherboards/server/s2400gp/sb/g50295002_s2400gp_tps_r1_02.pdf S2600GP Technical Product Specification. There you'll see that there are different SAS and SATA ports on the board (page 5 & 6):
SATA 6G port 0
SATA 6G port 1
SATA 3G port 2
SATA 3G port 3
SATA 3G port 4
SATA 3G port 5
SCU0 Mini SAS port (0-3)
SCU1 Mini SAS port (4-7)
There's also Intel® RAID C600 Upgrade Key Options to support the On-Server Board SATA/SAS Capable Controllers (page 42). However, there's no key required to support RAID 5 with RSTe. But if you want more than 4 ports (Intel® RSTE 8 ports SATA R0,1,10 & 5) you need the RKSATA8R5 (White) C600 Upgrade Key Option.
You also need to use the BIOS Setup Utility, accessed during system POST, to enable/disable SW RAID, and select which embedded software RAID option to use.
For Intel® Rapid Storage Technology (RSTe):
  • Supported RAID Levels – 0,1,5,10
  • 4 Port SATA RAID 5 available standard (no option key required)
  • 8 Port SATA RAID 5 support provided with appropriate Intel® RAID C600 Upgrade Key
  • No SAS RAID 5 support (SATA only)
John
