I have found a specification explaining how to connect one MFSYS25 (IMS) with an external to a Promise* VTrak E610s.
This not exactly what i want.
What i want to do is to connect one MFSYS25 to another MFSYS25 (by interconnecting the SAS external port of each MFSYS25).
You have understood, i would like scalability.
In such configuration :
- the first MFSYS25 (say MFSYS25-1) would host the 6 blades + the SAN
- the second MFSYS25 (say MFSYS25-2) would host 6 more blades (these 6 blades use the remote SAN offered by MFSYS25-1)
For MFSYS25-2 point of view, MFSYS25-1 would then appear as a pure external SAN.
Is it technically feasible ? (this depends of SAS zoning capabilities of your system, I guess)
For info ;
I am currently working with IBM to do the same thing between one HS21 (in a Blade Center-E) and one HS21 (in a Blade Center-S - hosting the SAN).
I have the two guys in lab, but for the moment, we did not succeed to make the HS21 (in the BC-E) access to its lun located on the BC-S.
If you have a solution to my requirement , then i will choose Intel IMS.
/Ronan GUILLOU
former Intel employee (at Intel France)
Test & Integration Director at CENTILE (www.centile.com)
- Tags:
- SAS
No, there is currently no way to use another MFSYS25 as just an external SAN
![](/skins/images/1FC86CD46823E418D1E2B7B4DC10231C/responsive_peak/images/icon_anonymous_message.png)
