Recently bought this cage from ebay. Unfortunately, no cables in package
I expected it will have SAS connectors on backplane, but it has what
looks like 4 SATA ports, yet I see elsewhere people (and Intel itself) talking about SAS
disks with this cage. Are SAS disks supported (maybe through non-standard
SATA cabling)?
Hello Branko,
Thank you for your patience.
The backplane is supported in the Intel® Server Chassis P4304XXSFCN and does support SATA drive only.
For cable, part number location, refer to the section named Configuration Option of the document found at Spares, Parts List, and Configuration Guide for the Intel® Server Board S1200SP, Intel® Server Chassis P4000S, and Intel® Server System R1000SPO Product Families
Here you can find some additional information about the installation:
4x3.5 inch Hot Swap Drive Cage Kit Installation Guide for Intel® Server Chassis P4304XXS
The supported backplane for this family S2600CW is FUP4X35S3HSDK
Spares, Accessories List, and Configuration Guide for the Intel® Server Board S2600CW Family
Let me know if you have any questions.
Adrian M.
Hi:
FUP4x35HSDK is SAS/SATA backplane. If you want to install SAS you need a RAID controller. Depend on it you would need MiniSAS(SFF-8087) or SASHD (SFF-8643 ) to SATA connector.
Also I recommend to look for I2C cable (HSBP to MAINBOARD) to update HS firmware.
Best regards
Hi and thanks for reply.
I already have SAS controller built in on my S2600CW motherboard.
However, since I know you can connect SATA disks using SAS cable,
but not other way around, I'm curious how SAS disks work in that cage,
if connected through SATA cable?
Hello Branko,
Could you please let us know where this FUP4x35HSDK is being installed? The model of the server and chassis.
Adrian M.
Hi Adrian,
its a custom built server, made mostly from ebayed Intel parts:
1. P4000M Intel server case with 2X750W power supplies and 8XSFF HDD cage
2. S2600CW Intel motherboard taken from (this was hard to find) Kontron CG2300 Carrier Grade Server
lots of ram, additional 10Gbps network card, and uncertain amount and types of storage, plus
additional SAS card in case its needed
Hello Branko,
Thank you for your response.
I will check into your last question and post back soon.
Adrian M.
Hello Branko,
Adrian M.
Hi Branko:
This backplane support SAS/SATA but it was used in P4000M chassis (page 121) with S2600CP boards.
g27488005_p4000m_tps_r1_2.pdf (intel.com)
Intel® Product Specification Comparison
FUP4X35S3HSDK is validated one for S2600CW.
Best regards
Thank you both. I have to highlight difference in your answers, it somewhat explains
how I got confused too
"The backplane is supported in the Intel® Server Chassis P4304XXSFCN and does support SATA drive only. "
"This backplane support SAS/SATA but it was used in P4000M chassis (page 121) with S2600CP boards."
Just reading the documentation, SAS is mentioned too often
