the issue I am trying to solve is this: my ZOTAC GTX 980 AMP! works fine in Core i5 desktop, but is not recognized in my Intel S5520HC mainboard where I would like to use it for some TensorFlow GPU computing.
The card is inserted into the only PCIe 2.0 x16 slot (mechanically, only x8 electrically) on the board. a Quadro K4000 card works fine in that slot, so the slot seems to be working.
I am wondering if this could be a PCIe 2.0 / x8 slot compatibility issue? Could this be solved e.g. by updated the GPU's firmware and/or trying other PCIe slots using a x8 -> x16 riser?
The Intel board is running the latest firmware/bios.
Anybody here have any experience with / recommendation for a modern nvidia GPU that is compatible with this board? something along the lines GTX 970 / 980 / 980ti / Titan X would be great.
Thanks!
Guenter
turns out that updating the GPU to the latest firmware from https://www.techpowerup.com/downloads/ Downloads | techPowerUp *did* fix the issue
![](/skins/images/7746D4550810124E96DD2FD9957552B1/responsive_peak/images/icon_anonymous_message.png)
