Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
4616 Discussions
RSTCLI on Intel C600 series SAS RAID Controller
SHawk
I have an Intel C600 series SAS RAID Controller with version 4.3.0.1223 drivers. I am trying to use RSTCLI to query the model and serial numbers of the attached drives. Unfortunately the model number does not seem to be reported correctly. For instance, where the model number displayed in the Intel Rapid Storage Technology enterprise GUI is "WDC WD1003FBYX-0" the model number displayed by RSTCLI is just "WDC". Obviously this isn't very helpful. Is it the space in the model number that is causing the problem? Is there a workaround?
Amy_C_Intel
Hello, @sam_hawker:
In order to better assist you I will move your post to .
SHawk
For what it's worth, I found a workaround. If you use the --xml command-line option then the resulting XML file contains the full model numbers.
