Hello Bambang,
Thank you for contacting Intel® Technical Support.
I understand that when attempting to install Windows Server 2008R2 the process is not showing the hard disk drive to where you want to install it.
In an effort to better assist you, can you please confirm?
- How many hard drives do you have connected to the server?
- Are you using an add-in card disk controller or the onboard controller?
Jeremiah A.
Hello Bambang,
I hope you are doing well today.
I'm following up with you to see if you were able to gather the information I requested before.
Please let me know your results.
regards,
Intel(R) Technical Support.
Hello Bambang,
regards,
Hello Bambang,
regards,
Hello Bambang,
I have not heard back from you regarding this case in a good while. I will proceed in closing this case. You can open a new case if you need more help from us; we will be more than glad to assist you.
Jeremiah A.
![](/skins/images/E799062D82CA2A220ED12C6FD1960495/responsive_peak/images/icon_anonymous_message.png)
