I finally got my S5520SC platform up an running today, but alas it is now a brick.
I was able to get into the BIOS settings, and I was having trouble getting Windows 7 to install. I enabled the boot setting for EFI Optimized Boot to see if that would help, and now my when my system starts nothing show up on the display. I cannot imagine why changing a BIOS setting would make it so that you can not even get back into the BIOS settings.
The POST LEDs show "D6" which means "Trying boot selection 6" - but I don't understand what that means or why nothing show on my display any more.
Any help or advice would be greately appreciated.
Cheers, Eric
Eric,
Can you tell us what is the status of POST code LED's?
and glad to get the machine configuration details aswell!
A little more background on my story...
When I first powered on my system it would not show anything on the display.
About 6 or 7 power cycles later finally the BIOS information started up on the display and I was able to go into the BIOS and change settings. When it did this the board would beep a few times, but not in a decernable beep code. I was able to boot from the suppiled Intel Server Deployment Toolkit CD (which has a pretty crummy user interface by the way). I was able to boot the Windows 7 Setup DVD, but it would not recongnise the disk as having a system partition.
Since enabling the EFI Optimized Boot, when I power it on it beeps a few times, no decernable beep pattern, but nothing appears on the screen. The POST LEDs show a code of D6, which translates to "Trying to boot selection 6" - but I have no idea what that means.
So far I think Intel have a serious bug in their BIOS.
Cheers, Eric
ok - I used the Clear CMOS jumper and now my system boots again - phew. There should be a strong warning in the manual about enabling the EFI Optimized Boot (just don't do it). As it turns out I would not want that setting anyway as it is incompatible with using the ICH10R RAID.
I was also able to get Windows 7 installed and running. Clearing the CMOS seems to have made it possible for Windows to install. When I get some more courage I'll try getting the RAID to work again, which is probably where things got screwed up in the first place.
Cheers, Eric
