Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
4615 Discussions
Integrated Intel(R) RAID Controller SROMBSASMP2
mfi0: 56507 (401357991s/0x0002/info) - Rebuild complete on VD 00/0
mfi0: 56508 (401357991s/0x0002/info) - Rebuild complete on PD 0a(e0xff/s10)
mfi0: 56509 (401357991s/0x0002/info) - State change on PD 0a(e0xff/s10) from REBUILD(14) to ONLINE(18)
mfi0: 56510 (401357991s/0x0001/info) - State change on VD 00/0 from DEGRADED(2) to OPTIMAL(3)
mfi0: 56511 (401357991s/0x0001/info) - VD 00/0 is now OPTIMAL
mfi0: 56512 (401358026s/0x0002/WARN) - Encl PD 00 Path 50001017c6b2ce00 reset (Type 03)
mfi0: 56513 (401358080s/0x0002/WARN) - Encl PD 00 Path 50001017c6b2ce00 reset (Type 03)
mfi0: 56514 (401358134s/0x0002/WARN) - Encl PD 00 Path 50001017c6b2ce00 reset (Type 03)
mfi0: 56515 (401358188s/0x0002/WARN) - Encl PD 00 Path 50001017c6b2ce00 reset (Type 03)
mfi0: 56516 (401358348s/0x0002/WARN) - Encl PD 00 Path 50001017c6b2ce00 reset (Type 03)ter
i get this warning after i changed my broken hard drive on runing system with hot spare. Can anyone help me with this?
Simis, What is it exactly you need help with? Regards, John
i can't find any information about this warning :
Simis,
If I'm reading that right, physical disk 0 in enclosure 0 requires reset command and the controller is predicting a failure.
Jason
But how can i fix it? because when i try to find it, i cant see any enclosure 0 or physical disk 0
mfiutil show config
mfi0 Configuration: 2 arrays, 1 volumes, 0 spares
array 0 of 2 drives:
drive 1 ( 279G) ONLINE SAS slot 1
drive 2 ( 279G) ONLINE SAS slot 2
array 1 of 2 drives:
drive 9 ( 279G) ONLINE SAS slot 9
drive 4 ( 279G) ONLINE SAS slot 4
volume mfid0 (557G) RAID-1 256K OPTIMAL spans:
array 0
array 1
What server system are you using? I would guess that it in this case you are looking for the disk in slot 1.
Jason,
My server system is Intel® Server System SR2600URLXR , OS FreeBSD .
i tried to change all physical disks but it will not change anything,
57672 (Thu Sep 20 08:25:24 EEST 2012/DRIVE/WARN) - Encl PD 00 Path 50001017c6b2ce00 reset (Type 03)
my config:
mfiutil show config
drive 10 ( 279G) ONLINE SAS slot 10
array 0
array 1
physical drives:
mfiutil show drives
mfi0 Physical Drives:
Hmm... just out of curiousity, which drivers are you using for the controller?
I'm no BSD guru, but I notice there's no BSD drivers on the product download page for that server board.
That driver supports LSI MegaRAID SAS 8408E and LSI MegaRAID SAS 8480E but the http://download.intel.com/support/motherboards/server/s5520ur/sb/e45274011_sr2600ur_tps_r1_9.pdf TPS (section 6.4.2) for that board quotes LSISAS1078. You might have a driver compatablity issue.
To expand on what Jason indicartes above. The difference between the LSI 8408E and 8480E controllers is just internal and external connectors. The LSI MegaRAID SAS 8408E/ 8480E controllers use the LSISAS 1068/1068E ROC.
Here's the LSI MegaRAID SAS 8408E/ 8480E controller http://www.lsi.com/downloads/Public/Obsolete/Obsolete%20Common%20Files/mr_sas_stor_ug.pdf User's Guide.
John
John,
I've poked around a bit on the Intel support site and I've not found any details about the SROMBSASMP2, can you point to a product landing page for that item? Or can you answer, does it use the LSISAS1078 as indicated in the TPS?
Yes, the SROMBSASMP2 or FALSASMP2 use the LSI1078 ROC. John
